Question about Technics SL-1200MK2 Turntable
Technics 1210s mk2
Everytime i put new internal fuse in it will play untill i touch or scatch the record then the fuse blows change styleses and earth still the same please help thanks
  • Jay Panicker May 11, 2010
    Toucing or scrathing the record increases the load on the motor and hence draws more current, blowing the fuse. However, it shouldn't happen as often as you describe. What is the marking on the fuse that you are using ? How many mA or A ?
  • 515 Answers
You have a short somewhere on your main PC board that is causing this. You will have to take it to a qualified service professional for testing.
There is no 'motor' per say on this model. It is direct drive, so there is no moving parts. A drive coil rotates the magnet that is located under the metal platter. This in turns causes the platter to rotate. You can stop the platter, and nothing will happen to the drive system. It's basically just not going to turn. There is no resistance occurring, which is the beauty of these turntables, and which is why DJ's prefer them to other models on the market - especially the Turntablist community.
More than likely there is something on the main PC board that is causing a short, blowing out the fuse. Look at R213 - see if there is a discoloration around it, also take a look at Q2 and Q3.
If you have no idea what I am talking about, then don't try to figure it out. Take it to a service center.
- OPTiC
The 1200s Expert
www.REPAIRNYC.com
Posted on Sep 08, 2008
  • 3 Answers
Do you have the ground cable connected to the ground on you mixer?
Posted on Sep 01, 2008
Everytime i start my car the engine fuse blows. I want to know what might be wrong with it? why is this happing? When i change it to a new fuse it burns that to
Hi there.
Well it could be either a short in the starter motor or the Key to solenoid or a wire touching earth like engine etc ,
so check wiring from ign switch as that switch could be the problem before going to far.
Apr 10, 2014 | 1994 Chrysler Town & Country
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
Me technic 1210s wont *** on ive tryed change in the fuses wiv 1 from tv an still nothing any ideas?
It could have got an internal fuse, not the one in the plug. Also the power switch might have broken. There's only one way to find out! Take the bottom off and have a look.
Jan 12, 2010 | Technics SL-1210 Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
Basically, have just bought 1210's mark 5's one of them, the tone arm makes the Brand New cartridge skip when it gets to certain points, its because the tone arm sort of swivels, like something is not...
i have this case now, i bought some mk2's. If u have a record that is single sided, put the side that dosent play on the slip matt, put the needle on it...add more weight if needed. it should stay where u put it, if it dosent...then it should be a case of moving the anti-skate, untill you are satisfied that it is not moving anymore. If u dont have a record like that, like i dont....i took the stylus off...and the slipmatt off...and let the cart run on the platter at 33, i hope it helps your problem, if i dosent then i would take it to a technician.
Jul 30, 2009 | Technics SL-1210 Turntable
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
Jan 15, 2009 | Technics SL-1210M5G Turntable
My technics su-a900 mk2 keeps blowing the internal fuse
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Nov 22, 2008 | Technics Audio Players & Recorders
Technics 1210 feedback/grounding problem
Since you've already replaced your RCA cables, and tried different cartridges, the only other thing that would cause this type of issue is your tonearm. It's probably on it's way out, and will need to be replaced shortly.
You can obtain a replacement tonearm HERE, however, it's rather difficult to replace the tonearm without experience or knowledge on soldering.
We are the 1200s Experts!
DIGITAL ANALOG THERAPY
Jun 09, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
209 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
