SOURCE: fixn my GE washer spin cycle
you are correct, the "leak" was from the over flow, and the "no spin" were all caused by the incorrect level indication. could not blow out the tubing so I replaced it...everything works fine now. thanks for your help!
SOURCE: maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
my washer spin and rinse cycles work but it will not fill with water is this expensive to fix
