Question about Ricoh Aficio CL7000 Laser Printer
Ricoh Afficio cl 7000 sc 552 code what is it?
Have a sc 552 code on a Ricoh Afficio CL 7000 what is that. Thanks. deancopypro@yahoo.com or call 801-427-5489
  • 1 more comment
  • Anonymous Mar 18, 2014
    SC 302 IN RICOH AFFICIO 1035
  • Anonymous Mar 20, 2014
    sc 552
  • Anonymous Mar 30, 2014
    paper keeps jamming
    Scholar:
  • 163 Answers
Check this out,
it may contain information about the code on the specs or features!
http://www.superwarehouse.com/Ricoh_Aficio_CL7000_DL/402371/p/417801
Posted on Aug 18, 2008
  • 928 Answers
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
  • Thomas Lim
    Thomas Lim Aug 18, 2008
    Press Enter
    Press Enter
    Press Enter
    Power off and on.
How to reset SC 302 code ?
sc302 is usually PCU or charge roller.
As you say you have recently replaced the Drum/PCU, is the drum turning correctly?
Check charge connectors and connectors on the back of the pcu. To reset that code, simply turn main power off and on again. If problem comes right back....the machine detects the cause still exists. May be an issue with the HVT.
Sep 01, 2014 | Ricoh RICMP201SPF AFICIO MP201SPF,...
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Hi I need a service mode code for a ricoh cl 7100
Press and hold both arrow keys for 5 seconds, let go then press enter. This will enter service mode. You will need to search through the menu system for the particular option you want.
May 24, 2010 | Ricoh Aficio AP3800C Laser Printer
RIcoh CL 7000 having problem within the copier, it's locked and unable to use WHat should i do
Most likely if you have no error code displayed then one of the hard drives is bad.
Feb 07, 2010 | Ricoh Aficio 450 Copier
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
Installation driver for Ricoh Aficia CL7000 laser printer
go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Sep 26, 2008 | Ricoh Aficio CL7000 Laser Printer
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio CL7000 Laser Printer Logo
994 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
