Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Not Freezing My 2 month old Frigidaire Upright Freezer has suddenly decided to stop freezing on it's own. It will work fine and then one day it stops. There is always a puddle of water on the floor around it when this happens.
  • 876 Answers
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Posted on Aug 18, 2008
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer comes off and on.
try leaving it uplugged for at least 6 hours after it has been moved in order for the oil and gas to seperate and settle. Then it should work okay
Dec 28, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire mod.# FFU20F9GW5
You have problem stil problem I thik its electrical you can send me copy of electric diagram to may email I can check for you and give posiable solution.
may email is : czesiek1948@op.pl
Nov 03, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Jun 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
254 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
