Cell Phones Logo
Posted on Jun 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia e7 caller display not working - Nokia Cell Phones
Christopher Lozada
Level 3:
  • Master 1,140 Answers
  • Posted on Jun 08, 2011
Christopher Lozada
Master
Level 3:
Answers
1140
Questions
0
Helped
276879
Points
3978
Is the caller number display or nothing at all?
if the caller number is displayed,check you contact,might have enter same caller number even if different names.
if not,try to reset your phone,go to settings and restore factory default or just type *#7780# for soft reset (nothing will be erase and back to default) or *#7370# for fukk format or hard reset (this will erase all of your data stored,be sure to back up important data defore proceeding)
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
1helpful
2answers
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Hey everyone i just bought a new nokia e7, but there is a big rpoblem that my ******** is'nt working please help me please i am so worried!
There is a linking cord for the display main panel to the main board and this could have snapped. SO it is best to take consensus with the Nokia support center , get estimate and replace.
If not there is fault in the motherboard. Claim for warranty if the set is less than a year old and do not tamper.
2helpful
2answers
NOKIA 6300 CALLER DISPLAY
try to go to a nokia care and i think they can solve your problem
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
