Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony explode amp
My sony amp doesn't work anymore i am currently going to school for electronics and i was wondering what would be the best place to start when trouble shooting the problem the supply or output?
  • 631 Answers
The following page will help you with the basics. Let me know if you need any help.
Basic Repair Primer
Posted on Aug 20, 2008
SOURCE:
Replace stereo in a 2004.5 Kia Spectra EX
Ebay is the best place to look.
Jun 17, 2014 | 2004 Kia Spectra
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
SONY PS-LX56P turntable sounding very quiet when attached to a mini Sony hifi, even though our other turnable sounds fine on it.
Not knowing the electronics I'd imagine a close listen would reveal it's actually tinny as well as quiet. You probably need a Phono Preamp (Google it).
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Jun 29, 2011 | Sony PS-LX250H Turntable
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
Jun 19, 2011 | Sony VAIO Notebook
I have a Sony DV-NS730P and it is currently not
Hi
Depends on what you paid for it. The error is an indication that either the laser head is misaligned or defective or the motor or associated head/motor electronics is defective.
Jun 06, 2010 | Sony DVP-NS730P DVD Player
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Sony explode amp ''OVER CURRENT'' light on -no sound
just feed 240V through the RCA inputs and check if the amp power light comes on. if it does the the amp should have automatically been reconditioned.... you are now ready to rock n roll!!!
Mar 23, 2009 | Car Audio & Video
760 sony explode amp in protection mode
I have a Sony X-Plod amp 760w 2/1 channel xm-1902gx. Everything is connected properly and the amp contains 4 lights (power,over current and two others). Power lights up like it's supposed but the over current lights up as well. I am unable to get any sound from it. Can you help me before I trash the amp.
Nov 01, 2008 | Audio Players & Recorders
D7401 doesnt work
There is no fuse on this amp. It requires EXTERNAL fusing, as it is a PRO amp.
There are diagnostic LED's on the board if you look inside. They may point you to a problem, but the odds are the amp is shutting down because it is detecting a problem. You need to take it to a repair shop for an good tech to fix. Unless you are VERY into electronics, and very knowledgeable about the operation and repair of car amps, I would not attempt to repair it yourself. It is a very nice, expensive, high power old school amp. The power wiring needs to be sufficient as well. This amp will draw ALOT of current at full power. (80 amps or so I think) there's manuals for it floating around the net with the exact specs needed for the external fuse).
Jan 09, 2008 | Diamond Audio D7401 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
122 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
