Question about InFocus ScreenPlay 5700 Multimedia Projector
Projector makes lots of noise
My projector is making lots of noise and i think that it is the cooling fan at the front near the lamp. If I replace the lamp will this solve the problem. My lamp is over the hours and is telling me to change lamp.
  • 2,326 Answers
If the lamp exceeded the lamps hours, it should be replace and the cooling fan as well if it's noisier then normal.
Let us know the exact model number to find the lamp.
Posted on Aug 18, 2008
  • 4,234 Answers
Typically a lamp will not make much noise other than a slight buzz. I would check the fan to be sure that the fan turns freely and that the venting for it is clear. If that is not the problem, please try to describe what kind of noise you are hearing. That should help to narrow down further the possible problem areas.
Dan
  • 6,487 Answers
Yes, that can solve the problem because there's also a possibility that the lamp is the one that is causing the noise..
Hope that helps........
The projector lamps always burning out. I think, the cooling system does not work?How does the projector work?
Make sure not to shut down the projector after use. Wait until the fan stops. The fan is to cool down the bulb during and after use. Once the fan stops, then you can shut it down.
Feb 29, 2016 | Office Equipment & Supplies
Infocus projector makes a whistling sound then shuts off
The whistling is nothing but noise. You need to open the projector to confirm the source of noise. It can either be mechanical or electronic. Possibility of mechanical noise sources are colour wheel (a 4 colour wheel near the lamp), blower fans & exhaust fans. All these are rotating things. If any one of them is jammed, then so as to try to rotate at full speed creates noise. To reduce mechanical noise it is necessary to service them. Dust is one of the main reason. For electronic noise check SMPS (Switched Mode Power Supply) & lamp ballast (electronic choke).The electronic noise is a high frequency noise generated by such devices. Are you using the projector in dusty envionment?
Nov 24, 2011 | InFocus Office Equipment & Supplies
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
The lamp on my Infocus Screenplay 7210 shuts down
the projector thinks it is overheating. you may need to replace the temp sensor. it located near the lamp plug. also make sure the fans are both moving.
Jan 24, 2010 | InFocus ScreenPlay 7210 Multimedia...
Lamp burn out 3 time in 16months
clean out your projector. if there is a lot of dust and/or no air flow, the lamp will overheat and die. it needs to cool. use canned air and blow out any and all dust from inside the projector. make sure the fans work. also, don't buy lamps from "bob's lamps". get it from a reputable benq dealer.
Nov 10, 2009 | BenQ W500 Projector
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
I got a Toshiba tlp650u projector broken on ebay. It works fine but after about two minutes turns itself off and then the fans come back on and the two power and lamp lights come back on red, which the...
Make sure the air intake filter has been removed, dissassembled and cleaned. Reset the lamp timer after replacing the lamp. Confirm allo fans are operational, and don't forget to allow for the cool down time after the unit is turned off. AC must remain connected for the unit to cool down the lamp after the unit is turned off.
Sep 17, 2009 | Toshiba TLP 650 Multimedia Projector
Sony KDF-E50A10 50 in. HDTV LCD Television has a ringing sound like a cellular phone whenever the TV is turned on. I have isolated it to near the projector. I have taken out the projector and it still...
There are more than 1 fan in the set; however, the last one to turn off is the lamp fan. The lamp fan keeps your lamp cool and helps extend the life of your projection bulb.
You could either replace the fan, or remove the fan from the set and give it a good cleaning (that's all it might need). However, be aware, fans that go bad in these sets will start to shut down your tv and decrease the life of your lamp. Be on the lookout for intermittent or sudden shutdowns, as those can definitely indicate a bad fan.
Jul 08, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
InFocus ScreenPlay 5700 Multimedia Projector Logo
420 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
