Question about GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven
Inglis F5E1 Oven model: IJP85801
I baked at high degree (450 for 45 minutes). The door locked started to lock and unlock the oven door. And then the error code F5E1 appear. I tried to unplugged and pluged again but the problem is recuring.....???? Any solution....???
  • 116 Answers
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Posted on Aug 31, 2008
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
I was baking dinner and the kids walked by and looked oven door. Now i can't get it to open. Its a magic chef/ self cleaning oven
Need to know the exact model to be sure, but usually there is a button that says "lock" or has a padlock icon that you press and hold for a minute or so to lock and unlock.
Also, if they started a cleaning cycle, that will lock the door, too.
Apr 21, 2011 | Ovens
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 | Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    While baking oven starts broiling with no input from controller. f2 is displayed on screen
    Hello there:
    F2
    Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
    · Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
    · Control senses oven temperature above 935 degrees F with the door in the locked mode.
    · Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
    · Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
    · Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
    · Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
    Sep 27, 2010 | GE JKP15 Electric Single Oven
    My oven code is F5E1 , my oven was in self clean , now the door is locked
    F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
    Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
    Hi.
    the oven may have locked in consequence of the self cleaning cycle.
    After unplugging, allow the oven cooling down for few hours.
    If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
    Parts must be tested to discover the fault.
    Call Kenmore at the number listed on the owners manual.
    Regards.
    Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
    The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
    Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    From "bake" mode, oven door locked, both heating elements on.
    The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
    This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
    If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
    If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
    Dec 21, 2008 | Whirlpool RBS275PD Electric Single Oven
    Kenmore oven locked
    Hello dktshopping,
    I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
    Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven Logo
    500 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
