Question about Samsung SGH-E360 Cellular Phone
USB CONNECT TO MY COMPUTER - Samsung SGH-E360 Cellular Phone
Has done thank you
Posted on Aug 19, 2008
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
Garmin navi will not connect to computor so i can register
You may need to replace the usb cable that you are using to connect this device to your computer.
There's just 4 steps on how to connect garmin navi to computer.
1. Connect the mini-USB end of your USB cable to the back of the Navi.
2.
Turn on your PC and connect the standard USB end of your USB cable to the USB port on your personal computer
3.Power on the Navi and give the computer time to recognize the device.
4.Click "Start," then "Computer." The Navi hard drive should be among those listed under "Devices with removable storage." You can click on the Navi's drive icon to access your Garmin device
Dec 26, 2010 | Garmin nuvi 255W GPS Receiver
How to use USB ports in BenQ E2420HD monitor? Can I connect pen drive..........
The USB ports on the Benq monitor is a USB hub. Connect a USB cable from the USB port on the computer to the input USB port on the Benq.
Then you can connect any USB devices to the USB port on the Benq and the computer will see this device.
Nov 15, 2010 | Computers & Internet
Suddenly the sansa will not synch with Windows Media Player.
When you attach your Connect via USB to your computer, verify that the Connect is displayed as a "portable media player" under "My Computer" in Windows Explorer.
If it isn't ... try a different USB port. The Connect requires a high-power USB port, which is typically found on the back panel of your computer.
If this doesn't work, try the Connect on another computer (just verify that it shows up under "My Computer", as I mentioned). If it does, you may have a problem with the installation of WMP on your computer ... try re-installing WMP, and make sure you install the latest version of WMP. If the Connect isn't recognized on the other computer, it's possible that there is a problem with the USB cable - get a replacement.
Jan 17, 2010 | SanDisk Sansa Connect MP3 Player
When i connect vivitar vivicam 3815 with usb to computer it does nothing!
Some cameras need to be configured to connect to a computer before connecting it to a computer. Please see your manual. If it doesn't need to be configured, try connecting it to another usb port on your computer. You have to make sure that the usb cable your using to connect the camera to the computer is not defective. Try using another cable. Also, try connecting another device to the computer using usb connection to make sure that the usb port is not damaged. If again, nothing happens, then you have to consider that the usb port on your computer is damaged and you need to contact your computer's manufacturer for it.
Nov 23, 2009 | Cameras
My USB mouse is not detected by Windows after I plugged in the device. what can i do?
HI,,
IF U R CONNECTING USB MOUSE IN COMPUTER FRONT PANEL ,,DONOT CONNECT
SOMETIME ITS DOESNOT SUPPORT ,DUE USB CONFLICT..
CONNECT USB MOUSE TO BACK SIDE OF COMPUTER...
BEFORE CONNECTIING RESTART COMPUTER AND THEN CONNECT....
TNKS
RABBANEES
Nov 11, 2009 | Warrior 797146022002
The connection to the computer is not working correctly. We have reconnected everything, and it is still not working
try another usb cable to connect the printer to the computer.. if the same check first the usb of your computer if it is okay..now check the usb port of printer. connect to another computer if the same problem cant connect it means the printer usb has deffect need to fix that
Sep 14, 2009 | Lexmark X3550 All-In-One Printer
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Jul 24, 2009 | Computers & Internet
General USB Troubleshooting
While USB connections are significantly faster and easier to set up than older serial or SCSI connections they are not foolproof. Here are some tips: Be sure to connect the cable properly One side of the cable is "keyed" so it will only fit properly one way. Do not force it in if it does not smoothly connect. Notice how the USB plug is "keyed" and will only fit properly in one direction. The USB connector on the back of the computer. Connect directly to a USB port on the computer. While USB hubs allow many devices to connect to a computer they are not always reliable for high-speed connections like digital cameras. Connect to a port on the back of the computer. Many computers have extra USB ports on the front or on the keyboard. These are generally built-in hubs which may cause problems as described above. Connect to an AC adapter or use a freshly charged battery To prevent problems during transfer be sure that the camera has enough power to complete image transfers. Remove other devices To troubleshoot problems, remove any other USB devices and connect just the Nikon product for testing.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Samsung SGH-E360 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
