Question about Kettler Kiddi-o Supreme Stroller Trike
Kettler Air Navigator Tricycle
Trying to switch from the fixed wheel position to the free wheel position - so the pedals will turn when bike is being pushed - can't for the life of me figure out the diagrams in the manual. Any help +++ appreciated.
Thanks - Diana
  • 1 more comment
  • angheli Aug 30, 2008
    Yes, I have the same problem. I'd like the pedals to turn so my son can get the idea of pushing on the pedals.
  • sttrane Nov 02, 2008
    we also have the pedals stuck so they won't rotate with the wheel. i called for support - they suggested something about taking off the hubcap and refitting a spring, but i can't figure it out.... : (
  • calicoast Nov 17, 2008
    I have a similar problem. Can't the pedals to lock in the "coast" position. Took the thing apart and it still doesn't work. Direction diagrams are useless. what the ??
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Posted on Mar 09, 2009
    New Friend:
Thank you for contacting Kettler USA Parts. There is no way to make a wheel that has the free wheel feature to be a permanent fixed wheel. The only way to make the pedals turn with the wheel is if the child pedals the trike. We do have a wheel from another trike that looks like the wheel on your trike but does not have the free wheel feature that you can purchase. Please supply us with a home phone number, address and the model# off of the round white sticker on the underside of your trike so we can supply you with a price quote for this fixed wheel.
Thank you,
Karen
Posted on Apr 08, 2010
  • Bob Thejob
    Bob Thejob Apr 06, 2015
    We just bought a Kettler tricycle and noticed the same free roll mode. I just took the wheel apart and put a cut-off 5mm rivet in the mechanism that engages the pedals when force is applied from the feet. This way its engaged all the time.
    New Friend:
We just bought a Kettler tricycle for our kid and noticed the same clutch-like feature. Really annoying.
Solution: Take the wheel off and locate the mechanism that engages/disengages the wheel and pedals. Its an inside-out gear wheel. When you pry the two parts of the inside gear wheel apart it engages.
So just put something about 5mm wide between the two parts and reassemble. I used a sawn-off 5mm wide rivet. Worked like a charm.
Posted on Apr 06, 2015
SOURCE:
Recently assembled and tried bike. There seems to be a catch/hitch in the rotation when pedal at bottom. It should be smooth. What could be wrong and how to fix?
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
Mar 22, 2014 | Kettler Giro GT Programmable Cycling...
Power Supply
Try emailing the parts department at Kettler USA: Kettler USA online shopping for tricycles pedal tractors ellipticals...
I used to have to contact them when I repaired Kettlers at the bike shop.
Feb 25, 2014 | Kettler Ergo Racer GT Indoor Cycling Bike
Front pedals
Yes, you got the bolts too tight on the axle shaft. You have to "sets" of nuts, the inner and the outer. The inner nuts on the shaft, which go inside the fork, should be adjusted so the wheel is rolling freely, with just a tiny "slop". Now, you will need to figure out a way to tighten the outer nuts to hold the wheel on the fork without turning or moving the inner nuts! Some bicycle shops use specially thin wrenches.
Be blessed.
Aug 08, 2013 | Schwinn 12" Roadster Tricycle
When the handlebars are turned, the wheel does not turn with them. Kettrike Air Navigator tricycle
  • It sounds like the quill insert is loose. The handle bar connects to the stem, the stem connects to the quill, the quill connects to the steerer tube.
  • while sitting on the bike, tighten the quill adjustment bolt a half turn at a time until the handlebars turn instantly with the front wheel.
Aug 19, 2010 | Cycling
Servicing
Locate where the noise is coming from, chances are the bearings have gone bad go to Kettler fitness.com they have contact info on their web site.
May 16, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
How can I fix slipping handle bars on kettler?
There should be a nut around the colum that comes up from the wheel and connects to the handlebars that is probably loose. If you can't get it yourself I have found that if you take it to a local bike shop they will fix these things usually for free or at a minimal charge usually less than five bucks. Take to a mom and pops type store you will get better service and like I said they will usually fix these things on the spot for free. hope this helps
Apr 05, 2010 | Kettler Kiddi-o Supreme Stroller Trike
Kettler Kiddi-o Supreme Stroller Trike Logo
3,124 people viewed this question
Top Kettler Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Kettler Baby Gear Expert? Answer questions, earn points and help others
