Question about Lexmark X3550 All-In-One Printer
UNABLE TO SCAN DOCUMENTS TO MYH COMPUTER
SCANNING WAS NOT SUCESSFUL
  • angie63 Sep 11, 2008
    Lexmark x5470
  • 876 Answers
Try uninstalling and reinstalling your scanner with a clean install.
Do yo have the original disc? if not you can go to this site for a download of your scanner driver.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Here is how to do a clean download and install:
If you have the disc or when you have located the correct driver for your machine, please do a clean download and install as follows:
Uninstall the previous software.
Turn off the machine and unplug it
Turn off all your running programs including your virus control
(look in the lower right corner and click on each little icon there and turn off everything you can)
Insert your disc for a new install
>>>If you don't have the disc-Now download the driver and SAVE it to your desktop
Click on it to install and follow the directions carefully.<<<<< When installation is finished, if it has not told you to reconnect your printer, do so now.
Restart your computer.
Good Luck. Please let me know if this works and rate my solution. Thank You.
Posted on Aug 18, 2008
Unable to scan on laserjet m1132 MFP
Hello you have to open the HP LaserJet Scan.
In the HP program group, select Scan to start HP LaserJet Scan
Select a scanning destination
Click Scan.
Here is a user manual in more details:
http://images10.newegg.com/User-Manual/User_Manual_28-115-668.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | HP LASERJET PRO M1132 MFP
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I have a HP Photosmart 2575 xi all in one printer and I need to be able to scan documents and photos. I have no idea how to do it. How do you scan these things. I use the printer and the copier but have...
1. Turn on your computer, wait for it to boot up, then turn on the printer.
2 Double click the "HP Photo Imaging Director" icon on your desktop ( placed there when your
printer was installed on your computer ). A menu screen will appear showing the scanning
options of the printer.
3 Place your document or photo on the printer's glass top and close the lid.
4 From the menu screen, click on " Scan Picture " or " Scan Document "
When "Scan Document" is selected, a secondary screen will appear from which you will have to
make choices. After making your decisions, click "Scan" from the listed screen.
When "Scan Picture" is selected, one scanning pass will be performed, another pass will be
made after you view the result of the first pass.
Scanned pictures will go to the HP Photo Gallery and your "My Picture" folder.
Scanned documents will go to your "My Documents" folder.
Good Luck with your scanning operations!!
Jan 21, 2011 | HP Photosmart 2575 All-In-One Printer,...
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
Jul 12, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Officejet & Vista compatability
Have you tried to use HP SOlution Center when scanning and save the scanned document to .pdf? try this solution.
Note: HP Director and HP Solution Center has more likely the same settings
CLICK HERE TO VIEW: DOCUMENT
Thank you so much.
adonscott
Feb 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP LJ 3020
The scanning unit is faulty, u may trying cleaning the scan unit ,else it needs replacement.
Happy printing
Omnipresent
Oct 17, 2007 | HP LJ 3020 All-In-One Printer / Scanner /...
Lexmark X3550 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
