Question about Saeco Royal Professional Espresso Machine
Saeco Royal Professional Coffee ends up in the bin not into the cups. What has happened and where can I go to resolve it. Thanks Mala
  • ravimalini Aug 24, 2008
    hi, the solution is not helping, the coffee still ends up in the bin.
    any other solutions?
    Problem Solver:
  • 11 Answers
If you mean the Coffee Seems to end up all around your brew unit, a common fix is to move the dosage control (this is the slide on the right hand side of your machine just above the door to the brew unit) back and forth repetitivly.
Try this
Paul
Saeco Coffee Machines
Posted on Aug 19, 2008
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
Hi. When I try to make a large cup of coffee, the machine makes more like a medium size cup. What can I do to fix that and get a true large cup? Thanks.
Hi!
When making a cup of coffee hold the button in until the coffee reaches the height you want then release button. You can set the 3 sizes in this manner
Ray AU
Feb 09, 2011 | Saeco Royal Professional Espresso Machine
SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Mar 30, 2009 | Saeco Royal Professional Espresso Machine
Can't figure out how to retrieve the menu.
I have a Royal coffee Bar and to retrieve menue, hold down the button to the right of the small coffee button, if you look above the button you will see a line running upward to "ENT" above the small coffee button is "esc" and use the medium and large buttons for up or down arrows.
I ma not usre if it is the same setup, however from the pictures it looks identical except my machine has single boiler.
Mar 17, 2009 | Saeco Royal Professional Espresso Machine
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get...
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Oct 06, 2008 | Saeco Royal Professional Espresso Machine
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Loud clicking and no coffee
Looks like your brew drive gears may be stripped. You should have a professional look at it because some must be causing the struggle to happen.
Saeco Service and Parts
www.cerinicoffee.com
Nov 26, 2007 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
140 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
