Question about LG 42LC2D 42 in. LCD HDTV
Supplying and replacing a LCD screen
Hi I am trying to locate a supplier for a LCD replacement screen on my LG 42LC2D TV
Doing Job OK with but can't find the parts
    President:
  • 2,961 Answers
I have spoke in the past to LG service and to buy an LCD screen actually costs more than a new tv.
Posted on Aug 18, 2008
Replacement screen for 42" LG LCD tv how much
The screen unit is called a display panel and if available the cost will always exceed the cost of a new set, not to mention some are sold on an exchange basis and have a core value.
Time to buy a new set.
Dec 04, 2012 | LG 42LC2D 42 in. LCD HDTV
TV has white picture only
If your TV have sounds but no picture or image only white screen..
The possible problem is T-CON board..T-con board is the responsible for picture on LCD TV..
Please try to replaced it to get your TV back to normal operation...
For specific parts and easy find the it online kindly get the part # of the said board (part # is located on the board itself printed with sticker)..
search it online using that part #..
Hope it helps..
Feb 10, 2012 | LG 42LC2D 42 in. LCD HDTV
MY PROBLEM IS THAT THE SCREEN IS CRACK AND NEED TO BE REPLACE
LCD Screen replacement would cost you approx 70~80% of new tv price. New tv is better option.
Aug 17, 2010 | LG 42LC2D 42 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Where can I find replacement screen for lg 42lc2d?
you can try through LG support which would be through www.lg.com or you could try the display division www.LGDisplay.com (slightly differant in several countries)
A replacement screen is not going to be even close to cheap. I would expect that a new TV would cost lest.
Apr 23, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LCD Screen broken Help!!
Not worth repairing.The LCD screen is 90% of the tv.It limitted produced,it cost about the same as a new tv to replaced.Even more after labors.
Apr 05, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a 42JC2D TV. Vertical color bar lines
It is hardware issue related to LCD Panel (screen).
Regarding fixing it, it depends if you are handy with electronics stuff repair and can replace circuit boards in tv etc then please check T-Con (lcd controller board) on top center position at rear of lcd panel, this board would be covered with metal shield. Need to take off back cover of tv to get access to T-Con board. If T-Con board does not solve lines problem of screen then LCD Panel is bad and will be replaced.
If you fee uncomfortable doing so then repairman option is better choice.
Hope this info will help you.
Thanks.
Feb 27, 2010 | LG 42LC2D 42 in. LCD HDTV
On my LCD TV. a series of vertical colored lines scroll across the screen instead of a picture, however sound did play. What could this be?
First you can try adjusting the cable to the LCD Controller (LCD CONTROLLER 6870C-0080D from LG 42LC2D) Sometimes the contacts get out of alignment and disconnecting/reconnecting it will clear it up. Do not touch the contact points.
If this does not work, you may have to replace it.
Mar 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Replacement lcd screen
I have broken Screen how or where can i replace it? (model 42lc7d)
Jul 31, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
1,372 people viewed this question
Computer Repairing
Computer Repairing
