Question about Compaq Armada M700 Notebook
How to do this?
Thanks for ur help so far!
so if i shut down the laptop stick in my NT workstation cd will i b able to delete everything? im not sure about partitons and reformatting,how do i go about this?also i picked up the 2009 virus tht appears to be a microsoft/windows,the one tht uses the same colours ect.
i assume scrubbing the laptop will get rid of this?
so many questions sorry, once i think of one they just keep coming!
thank you
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
No worries..I'd suggest a clean drive approach, yes.
Posted on Aug 19, 2008
SOURCE:
There is only 1 usb port on this computer, and Im not sure how to find out if it will support a multi usb out. it is an older Dell C600 latitude model PP01L running on Windows NT workstation 4.0(really...
All USB sockets support that, it's in the standard. But for ease of use it will be better to use a hub. But because it's such an old laptop it will surely be an 1.1 type, and the speed will be very slow.
Dec 26, 2010 | Dell C600 (002UH) Motherboard
I wanted to know how to properly reformat the acer laptop travelmate345T?someone say that i have to press f10 until it will appear the cd installer from the external cd rom im using right now and press the...
For completely reformat the drive you need any operating system CD.
Like windows xp,windows vista windows 7 etc.
Then boot from cd and when you when partition manager show just delete all the drive and reallocate the space for new drive part.
Be sure you need to install new os to get working the computer and also Be sure that YOUR ALL DATA WILL BE DELETED.
BACKUP EVERYTHING BEFORE DELETE IT.
Dec 01, 2009 | Acer TravelMate 345T Notebook
The pc stuck when shut down.
please formate ur laptop..ur problem will be solved...
Mar 01, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Need help reboot my computer
Hi.. first of all when ur system gets attacked by virus or threats its difficult to perform delete operations. The only best way is to format ur system with the help of XP cd. This XP cd will reboot ur operating system so that all viruses and threats available in ur C drive will get deleted... So the only option is to re install ur OS with XP cd...
thank u
Jan 26, 2009 | E-Machines W3503 PC Desktop
I need to format my windows nt 2000 professional sp4 pc.what r the things i need to backup? also i need the all the drivers and chipsets and motherboard etc...particulars to be installed after...
if windows 2000 is installed on c drive
put a win 98 bootable cd into cd drive
go to bios setup by pressing DEL OR F2 OR F10 keys on ur key board.
restart and boot frm cd
for back up
take my documents,desktop,mails (if u have any email softwares) ur data. to any other local disk.
windows office drivers of ur mother board
give me ur m.b details so ican give ur driver details
thank you
Jan 21, 2009 | Computers & Internet
Need Instructions on this...
In order to upgrade to XP with a fresh install, you will need to purchase an XP disc, then it's simple. Upon start up you need to go to the boot menu or set the cd drive to boot before the hard drive in the bios. Then insert the disc and follow the directions. At one point, you will need to delete the existing operating system in order to install the new. Once this is done, then you will need to format the drive using the full NTFS format, not the quick format. Then it's all down hill, just follow the direction. After the install, you will need to go to Compaq's support site and download any drivers needed. You can find the needed drivers in the device manager. I realize you would like to get around the XP purchase, but unfortunately, there's no way around it.
Aug 20, 2008 | Compaq Armada M700 Notebook
I want to delete everything and start over!
you'll need to go to SAFE mode, or boot from the install disk, which ever is most accessible.
http://tinyurl.com/6qcpgy
Aug 17, 2008 | Compaq Armada M700 Notebook
How to perform a clean install on the old laptop
Rather then loading NT, I would just load XP.
Xp actually is, NT 5.+
It will run on that laptop with out any problems.
I would suggest, however, that you have at least 512MB of RAM (more is better)
When you boot to the XP disk, you will have options on what to do.
One of the options is to delete the existing partition. If you have removed any data you want to save, delete the partition, and then continue with creating a partition, formatting, and loading (they pretty much walk you through the steps on the install).
Note to the above....when you delete the existing partition, any data that is on the computer is gone. So make sure that you have looked it over before doing that.
You will also need to make note of onboard devices beforehand so that you do know your onboard devices (sound, video, NIC etc) and you can make sure to have those drivers inhand before you start. XP has a number of them built in, but some, you will have to go to the HP/Compaq site to download.
If you need any additional information, you can find me here..
Aug 17, 2008 | Computers & Internet
No AM!
A possibility is that the antenna cable/plug is shorted. You can try verifying this with a continuity tester or simply unplug the antenna and stick a piece of insulated wire with the tip/end stripped into the antenna. Try the AM with the wire as the antenna. Just be carefully not go that far as the wire may reach the PCB/electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Pioneer DEH-1000 CD Changer
Cybershot F505 with Windows NT?
USB is not available with NT4.0 It will be available with Windows2000 however. I'm running NT on both my workstation and laptop and am buying the F505 myself as soon as I find a dealer that stocks them.
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Compaq Armada M700 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
