Hi EdwardFreman, because i can't see your computer now, i will higly reccomend you to check several things:
1.all power connections and data connections are connected, esecialy the hard drive ones.
2. check both cable ends from your computer to the monitor for broken pins, if there are just buy a new one.
Test the PSU if the units fan is not working the power supply unit is faulty One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test all leads that attach to your hard drive including electrical extensions IDE,SATA the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
