Nordyne condensing unit (S3D020400401) is it under warrenty
Our air conditioner quit working, it is nordyne
  • 182 Answers
Check fuses and breakers first.maybe electrical,maybe mechanical
Posted on Aug 18, 2008
Water does not evaporate why?
That air conditioner has a cooling coil that drips water into a formed plastic pan at the bottom that the coil sits in. The condenser sits in a pan similar to the pan previously mentioned. The pans are connected by a tube that allows the cooling coil water to find its way to the outside area under the condenser. The condenser fan outside has a ring attached to the end of the blades called a sling ring. As the fan spins it picks the water up and "slings" the water against the condenser thus getting rid of the water through evaporation and giving the air conditioner an additional 13 percent more capacity. If you drill drain holes I have seen units quit working because that additional capacity is engineered into heat rejection. Hope I helped good luck.
Oct 09, 2014 | Amana AH123E35AXAA 11,600 BTU Room Air...
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
We have a hvac Nordyne model P3RA-048K Everything
Hello
Either the filter is clogged and needs to be repaced.Or check the coil inside the unit and see if it is getting iced up.You can try shutting the unit down for an hour or raising the temp.If this helps the motor speed then you know the coil was iced up.
It is also possible the motor may be going bad,doubtfull though since they will run for a while then shut off.
Check your filter
Check for ice
Possibly clean the inside coil.
Jul 31, 2011 | Intertherm P3RA-048K Air Conditioner
Need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
May 15, 2010 | Intertherm P3RC-030K Air Conditioner
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
179 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
