Question about SanDisk Sansa m250 MP3 Player
Files , I want to delete are invisible.. when searching device files...
Hi, I try and view all the mp3s on my Sandisk M250 and , .. As I view all files that are supposedly on the device , I have about 463 files and many are multiples downloads..of the same songs!! The ones that , I want to REMOVE are invisible.. should , I try accessing it through , Internet explorer.. and my computer? I'd greatly a[ppreciate any suggestions you may have... Thank You, Rebecca Duarte"
It's kind of crazy, but here's what works for me (pain in the **** too). Some of the songs, you can see in explorer IF you set the MP3 player to Autodetect. The rest of the songs you can see if you switch to MSC.
So to be able to see all of the songs, I need to switch from one to another. I suppose that if I reformat the mp3 player (after having backed up all songs). Then I can choose just one mode to upload the songs.
I'm guessing that it has to do with differences with rhapsody, windows music player from XP and windows music player from Vista. But not sure.
Go to MENU>> Settings>> USB >> and switch between 'auto detect' and MSC.
Posted on Oct 16, 2008
    Problem Solver:
  • 18 Answers
I have the same problem, and the proposed solution doesn't work. To clarify, there can be audio files on the device that are invisible to Widows Explorer and WMP (I am using XP), although they are still there when you use the player. These are visible in plaintext in the file MTABLE.SYS but if you edit it with, say, Notepad, the device rebuilds the MTABLE.SYS file with all the files you would like to delete. If you check the properties of the MUSIC folder only the visible files show up, and deleting that folder along with RECORD and AUDIBLE does no good whatsoever. Probably related is the fact that in WMP the Sync view "Sansa m250" device reports sucessful "Sync Results" but "Artist","Album","Songs", etc all declare "there are no files on this device" even when you've just synced non-invisible (deletable) files to the device. Apparently the device has a proprietary file system and is faking, unsucessfully, its responses to the applicable system calls. Or somesuch screwup.
Posted on Oct 13, 2008
  • 55 Answers
Follow me --->>
1/my computer
2/ click twice on removable disk "F: or E: somtimes "
3/ delete & dowload whatever u want
dont forget rating this post if this is not helping u tell me so i can help u further .
Posted on Aug 20, 2008
SOURCE:
How to delete songs from my Sansa m250?
When you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.
You will then be able to select the music you want to play by the music albumfolder.To delete a filefrom your MP3 player, connect the supplied USB cable to your player and thenplug it into the USB port of your computer.
The computer will detect your player then click on this device to view thefiles, you can then click on the music file to highlight the file and thenpress the Del key to delete the file off your MP3 player.
Mar 25, 2012 | SanDisk Sansa m250 MP3 Player
Unable to use SanDisk Sansa M250 MP3 player with Vista. I try to drag and drop files to device, but when I disconnect from PC it says there are no files. I am unable to run any files from the mini CD.
There is support on the Sandisk site when needing files to download.
See the overview for the m200 series:
http://kb.sandisk.com/app/answers/detail/a_id/4487#m200
When the player says there are no files after a transfer,
the device may need to be formatted, see next site:
http://kb.sandisk.com/app/answers/detail/a_id/3/related/1
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250, can not see the files nor delete them
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 29, 2009 | SanDisk Sansa m250 MP3 Player
How to restore a sandisk sansa
Hook it up to the computer, right click on > My computer, > chose explore > look for the device and open to view folders, there may be files on it that are needed to run the device. Look for folders that have the things it them you know you can delete. and high light those items and click delete.
Sep 18, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250
Hi drruss,
I made the research for your convenience. Please try the link below;
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
Regards,
Jay
Oct 21, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Loading ALI podcast
I am sorry to tell u but the sandisk sansa m250 model isn't suppose to hold podcasts of any kind. It is only suppose to play music, recordings and FM tuner.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk 1GB Cruzer Micro with U3/ Can't view files
Which antivirus are u using? U should update it. or Try with Norton or MCaffe antivirus.
other wise u can search for any hidden files exists in the drive. For this goto Tools then FolderOptions then View then check Show hidden files and folers and Search the virus name by using Start\search options
Dec 02, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Sansa m250 MP3 Player Logo
155 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
