Question about Philips Magnavox Learning Universal Remote
Programming my AT&T remote control
I lost the remote to my Orion TV and would like to program my AT & T remote control to it so that I may use my cable as well as my PS2!
Check out this PDF....you should be able to figure it out from there:
http://helpme.att.net/pdf/uverse/remote_control_user_guide.pdf
Hope it helps!
Posted on Nov 17, 2008
What is universal remote code for bd-2000 on rcrno4gr remote
Remote code for HP BD-2000 Blu-ray player - AT&T Community
https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
Programming the RCA RCRN04GR Universal Remote
voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
[PDF]Rcrn04gr - Universal Remote Control Codes
Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
Help wit programing
Programming instructions to this remote is too much to type in here. If you wish to get more details about the programming instructions, Visit the site Electrohelponline or Electro-help for more setup codes. It has setup details and setup code list to different popular brand remote controls. Search for it by any search engine.
May 24, 2013 | Televison & Video
I lost my programming list so I cant oprate my tv I need the codes for orion
Hi
Five digit universal remote code for Orion TV with RCA RCR04GR remote control are:
10463 / 11463
OK.
Jul 13, 2011 | RCA RCRN04GR Remote Control
I have an rca universal remote model numberrcr350 i cant get the code for an orion tv and how to do it
I found 3 codes: 1030, 1035 and 1191.
Code 1030 for Orion TV Code 1035 for Orion TV Code 1191 for Orion TV
For other devices, try the remote code finder http://remotefinder.rca.com/default.aspx?site=rca . Try the search twice if it gives you a problem the first time. At times, the search engine has server issues. Please note that if the remote was programmed less than 6 months after the TV was released or is older than the TV, the code you need may not be part of the programming. In that case, you need a newer remote or one that is programmable (via a computer's USB port for example).
I hope this helps.
Sep 30, 2010 | RCA RCR350 Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
I have and RCA RCR311ST Universal Rmote Contro which I can not seem to find the Cole Selector button to program my Orion TV any ideas?
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Jan 20, 2010 | RCA RCR311S Remote Control
ORION REMOTE LOST
Orion has made Emerson,Sansui, Admiral, Memorex, RCA, Toshiba, Insignia, Akai and Zenith.
Try those codes. You can call Orion at 800 289 0980. I think the replacement remote for the FTDV2004B is less than $20.
Nov 07, 2008 | Orion 076D0FH020 Remote Control
Lost Remote
try www.partstore.com and see if they have the originald remote for your tv.good luck
May 13, 2007 | Orion 076D0FH020 Remote Control
Philips Magnavox Learning Universal Remote Logo
4,408 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
