I would start by making sure the energy saving features are turned off for the network card.
Here is a link to a video that should show you how:
How to turn off Power Saving for LAN Network Card on Windows XP Vista 7 8...
SOURCE: How do you stop the registration reminders for Lexmark X5070?
Go into Safe Mode, then Explore/Windows32 directory and look for any files with "Lexmark"; usually you can figure which files are the ones, even if they are not exactly named "Lexmark".
Next, go into Start, Run, type Regedit you are now in the Register. remove only what you exactly need to remove .
Dial this structure:
H_KEY LOCAL MACHINE
SOFTWARE
MICROSOFT
WINDOWS
RUN
Single-click on RUN; in the Right pane are all the programs that are loaded to run on boot; look for any references to Lexmark and delete them. At least that will stop the Lexmark drivers from loading. While you are at it, click Edit, Find, type in Lexmark and search the whole Register for Lexmark references and delete them. It will help to clean out your register a little, but be careful. If you don't feel comfortable doing this, then it's really not necessary for your particular problem.
SOURCE: Printer Driver Setup Error : Access is Denied I
Please get the correct driver here :
www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__hcgy643
SOURCE: Every next day, while starting client computer
this problm of windows or hardware problm u checkout the any computer repaing center they solve tour problm
u change the powersupply , ram, tight karo processor or fan ko .
and change the window
SOURCE: Corrupt Pptx files. Need to repair them. Please help!
1st. Try to find the temporary file when you creating it
When you edit a presentation, PowerPoint creates a temporary copy of the file. This temporary file is named PPT####.tmp.
Note #### represents a random four-digit number.
This temporary file may reside in the same folder as the presentation. Alternatively, it may reside in the temporary file folder.
Step 1: Look for temporary file in the documents folder
Windows Vista
Click Start, and then click Documents.
Look for a file that is named PPT####.tmp.
Windows XP
Click Start, and then click Run.
In the Open box, type %userprofile%\My Documents.
Click OK.
If you do not find the file, you must search for it. To do this, go to step 2.
If you do find the file, go to step 3.
Step 2: Search for the temporary file
Windows Vista
Click Start, and then type PPT*.tmp in the Start Search box.
Press ENTER.
Microsoft Windows XP
Click Start, and then click Search.
In the Named box or in the Search for files or folders named box, type PPT*.tmp.
In the Look in box, click My Computer, and then click Find Now or Search Now.
Step 3: Rename the file, and then try to open the file in PowerPoint
Right-click the file, and then click Rename.
Change the old file name extension from .tmp to .pptx so that the file name resembles the following file name:
PPT####.pptx
Start PowerPoint.
In PowerPoint 2007 click the Microsoft Office Button, and then click Open. In PowerPoint 2010 click the File menu, and then click Open.
Browse to the folder that contains the renamed file.
Try to open the file in PowerPoint.
Note More than one file may correspond to the temporary file that was created the last time that you saved the presentation. In this case, you may have to open each file to see whether one is the temporary copy of the presentation.
2nd.
PPTX Repair Kit is the only online PPTX repair tool that you will ever need to restore the contents of a damage PowerPoint presentation after a system crash. Fast, intuitive, stable and thorough, it is absolutely irreplaceable for anyone trying to find out how to repair PPTX file online.
For more information: http://www.pptx.repair/
If this way didn't work, try to find the answer here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/488-pptx-file-is-giving-an-error-and-can-t-be-opened
