Question about Refrigerators
After power outage, freezer working, but fridge did not cool again
I am a renter with landlord in another state and can't wait days for help. THANKS
T-storms last night and apparently only the fridge and computer(of course) outlets failed. Were on this AM, but everything in fridge = room temp, but everything in freezer frozen. Friends said just wait and it will cool. 5 hours later it had not -
Took everything out of the freezer to find vents at back were all covered in ice. Took plastic implement and carefully cleaned out about a cup of powdered ice. So far (30 minutes) do not notice any cooling in fridge nor feeling of cool air coming down into fridge. The fan in freezer is going strong and all has stayed frozen in there.
Should I call someone or just wait or ? THANKS SO MUCH
    Genius:
  • 1,269 Answers
Try to wait for couple of hours. If it still does the same thing, better call someone to check the freon and fan..
Posted on Aug 18, 2008
    Sergeant:
    Champion:
  • 298 Answers
How long was the power out...
  • kristopher betzler
    kristopher betzler Aug 18, 2008
    if the power was out for a while the freezer will defrost some ...not the inside but around the inner liner and fill the transfer register with liquid the when the power is restored it will freeze suddenly and block cool air to the frig.
    putt your stuff in coolers if you have any, turn off the frig let it thaw. 6 hours or so maybe less. then turn it back on that should fix it.
    i have run in to this before.
    if it worked fine before the outage the coolant and fan are fine ...you say the fan is going so that is good.
    freon is no longer used. do to (epa).
I have turned my fridge freezer off during 5 weeks. Since I'm back it's back on again, it cools and the freezer is freezing... but every day it rings and indicates that the freezer temperature (the re
Laurie a lot of people forget to leave the fridge and freezer door open slightly and the water from defrost hiding behind the rear wall of the freezer will keep the inside of freezer and fridge damp this will cause the freezer fan motor to rust and stop air circulation. Can you provide a model number? Thanks John Tripp Appliance 911
Contact me Here
Oct 22, 2014 | Refrigerators
No hot water
Lady may be tight, but she demands her rent on time and you no doubt pay more than the rental is worth. Most State Laws require landlords to make repairs within a reasonable period of time after the renter request service. Tight or not; she is responsible for the rental and you have Renters Rights. If you can't get her to fix the problem, withhold the rent and see how fast she reacts. Tell when she fixes the problem (In writing) you will pay the rent. If she tries to mess with you, report her to the State Rental Authority.
Mar 05, 2014 | Intertherm Heating & Cooling
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
Freezer is not getting cold not sure if it is stuck in defrost mode
Freezer not getting cold, then defrost problem is rare, it can be compressor issue.If freezer getting cold but fridge not getting cold, then yes it can be defrost problem. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------- But in your problem, you mentioned, in that freezer section is not stating cooling.So the compressor can be the issue.But still try reset procedure and see, if that is helping. Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If still the same problem, then the compressor has to be inspected.
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Apr 25, 2011 | Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Refrigidaire refrig that goes warm
cause is defrost system not working. could be defrost heater, stats or defrost timer
Sep 06, 2008 | Refrigerators
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
