Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Attaching potable dishwasher
Hi, I just renterd a house with a GE Nautilus freestanding dishwasher with no manual. I'm turining the adapter around and around and it wont screw onto my Delta faucet. How do I do it, am I missing a part?
  • 706 Answers
Did you remove the existing aerator from the faucet nozzle first? If not, that's your problem.. If you did..then look at the adapter to see if the therad pattern on the end looks like the thread pattern of the aerator you've removed.. If it does.. then you need to install that one.. Sometimes ..you can get them started by rotating it into the faucette backwards a few turns and then rotating it forward until the threads get started properly..after that.. just tighten it in place.. Hope that helps !
Posted on Aug 19, 2008
GE Nautilus dishwasher won't continue through cycle unless pressure is applied on door.
Hi, In reading about your dw problem, you are in need of a complete door switch assembly. You will need the full model number, and then find your nearest ge supply house to purchase the part. Hope this helps.
Jan 20, 2011 | GE Nautilus 24" Built-in Dishwasher
My GE nautilus dishwasher does not start and not getting water supply.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 20, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher - Does not stop filling with water
Hi
Thanks for using FixYa. If the dishwasher is overfilling it's caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Just put in this nautilus dishwasher which worked fine in the other house is not working now. Where is the manual restart?
check wiring is the plug in working is check gp outlets are they all reset,check brakers is the cord ok ,were the cord goes to dish washer is it secured?
Aug 29, 2010 | GE Nautilus 24" Built-in Dishwasher
PUMP DRIVE SHAFT IS LEAKING AT THE PLASTIC HOUSING
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
6789searhg
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Connector to the faucet for GE Nautilus portable dishwasher
We just bought a used version of the GE Nautilus and we were able to get a generic "fits most portable dishwashers" adapter and it worked great. We went to Fred Meyer (which I believe is a Kroger company in the NW) and it was the only one they had. It only cost $3.99. The brand is Plumb Craft by Waxman and the model number is 76-127. Dishwasher Faucet Aerator. Hope this helps!
Good Luck!
Dec 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
245 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
