Question about Panasonic Home Theater System System
PANASONIC SURROUND SOUND SB-WA3300
Gift of 2nd hand PANASONIC SURROUND SOUND SB-WA3300 set with DVD player, but no manual.
This model is not mentioned in existing blogs or faq's on this site.
Can't get sound out of anything but the Sub woofer (all 4 x small speakers are silent) Checked all wires, gone through all the set ups we can find on screen via the hand control - but no joy. I guess I need a manual but again most manual sites don't list this model (I guess it's an older one?)
Can you help please?
Petrina :o)
  • pmcn111 Aug 29, 2008
    Thank you ..
    Our system is now working!
    I admit that in the end we just waited until someone techie enough came to visit and they set it up for us! .. but I have no idea how they did it, and so the need for purchasing a manual at some point may be required - with your advice I know know what to look for and where. I had a quick look at the links and you are right, the number I had was just the one component, and now I can find the whole system!
    Thank you for your time and advice
    :o)
May be wrong number. SB-WA330 is name of speakers and search http://safemanuals.com/ to give you the right manual
Samuel
Posted on Aug 29, 2008
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Hi, I have a Panasonic sa-ht870 DVD home cinema system to which the remote has stopped working however the front 2 speakers still work and so do the controls on the DVD player. I bought a new remote and...
Is it a universal 'Generic' remote or dedicated Panasonic for the SA-HT870?
If generic, it may not have compatible firmware built in for Surround function.
If dedicated, check menu settings and OP manual - there may be an option that is disabled there.
Oct 28, 2017 | Panasonic Audio Players & Recorders
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
I have a Panasonic Surround Sound system model number SB-WA 730 Background music comes thru but we can not hear them talking - it is like it is muffled in a land far far away
Make sure center speaker is connected.Look in owners manual to reset, unit might be in an incorrect surround mode.If listening to a stereo source, take it out of surround.
Jul 21, 2008 | Panasonic Audio Players & Recorders
Set up the Panasonic SC-PT450 and followed all the various instructions. Am using the surround sound in conjunction with a Panasonic TV bought at same time (50" plasma) but can't seem to get sound out...
Are you sure you're using a source material that is surround sound? Most TV broadcasts are still only stereo.
Also with surround programmes, the rear speakers are only used for the surround effect so will only make sound when the sound source is supposed to be behind you.
Jun 25, 2008 | Panasonic Televison & Video
Panasonic Home Theater System System Logo
432 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
