When charging the 5045 with a wall charger how do you know when it is fully charged? the battery indicator shows 2 gold lines and then turns to escalating blue lines. are all the blue lights steady or what? the user handbook tells you nothing!
thank you , john fronk
Question edited for clarity, full make model (what it is).
Did you follow Section 9 about fully charging the battery, pressing and holding the button?
Charging Instructions 1. Plug the charger into the mains - the charger indicator light will be green.
2. Turn on the battery by press and holding the power button until the green light is illuminated.
3. Plug the battery into the charger. The charger light will turn from green to red to indicate the charging process has started.
4. Once the battery is fully charged, the charger status light will be
<p>Apple iPod touch is a personal audio player with the ability
to store and play MP3 files, digital video and downloadable games and
applications. The unit is powered by a rechargeable battery. When charging the
battery for the first time, ensure that the battery is fully charged. From
there you can turn it on or removing the device from the charger, if desired,
regardless of battery level. <br />
<p><br />
<p>1. Enter the main connection for the iPod cable to the
socket at the bottom of the iPod touch. <br />
<p><br />
<p>2. Insert the small plug into a USB port on your computer.
Turn on the computer. Alternatively, an iPod charger, sold separately, you can
recharge your iPod touch with a socket. Connect the wall charger into an AC
outlet. Insert the plug on the door of the small wall charger. The battery icon
located in the upper right corner of the screen, the battery is charging. <br />
<p><br />
<p>3. Let the battery fully charged. When the battery icon to
indicate the device is fully charged, remove the iPod from the cable. <br />
Hello Michael. Fully-charged batteries should indicate a green light on the battery charger and should illuminate all the five LEDs on the Joystick. The batteries should take about 8 hours to be fully charged. If you charged them for less hours there is a possibility they were not fully charged. If you feel you charged them for enough time and the battery charger showed a green light, that is frustrating, but there is a chance either the charger or the batteries are faulty. Substituting both the charger and batteries or either of them may be the best solution.
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the
fully charged state for two hours. (You may use your iPhone during this
time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone: #1 - Charge your iPhone throughout the day when available. Charge EVERY
night, regardless of charge level. This will keep your battery active,
which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer
chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect
the iPhone from the charger after it's done charging. Once fully
charged, the iPhone will run strictly off of AC power and will not
damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the
battery, in one cycle. This calibrates your battery indicator. If you
fail to do this, your indicator will become inaccurate. Calibrating
your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure
your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily
remove the case). Charging your iPhone inside your case will make the
iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a
cool environment has a tremendous impact on your battery's lifespan.
The colder the location you use to charge, the more charging cycles you
can complete without your battery deteriorating. Avoid charging in
direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly
rated will have a huge impact on your battery's lifespan. Make sure
your car charger has the same rating as the official Apple charger. The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A Thanks!
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
When batteries are placed into the charge mode, the red light will come on. When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
