Question about Lincoln Conveyor Oven - 1133-000-A
Lincoln impinger 1300
Oven heats up, then cools down once it gets to temp. Have to reset to get it hot again. Any solutions?
Check the air vents, Dust could be blocking air from cooling the circuits.
Posted on Aug 24, 2008
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
Oven is not heating what should i check
If it's getting power and the fuses are not blown it sounds like a bad heating element.
Jul 20, 2014 | Lincoln Impinger Electric Countertop Oven...
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
My Lincoln Impinger 1450 Gas conveyor oven may be having a thermostat problem. I have a double decker and it is only happening on the more-used one. The top oven has trouble maintaing heat. It will heat to...
is your blower working? if the blower is working it sounds like the sensor may be going out(or Out)! which is bascally the safety so the unit does not burn all other components up thats why it is needing to cool down to restart. check your fuses first make sure none of them are blown and only replace with the recommended size not just what is in there. Then work it from there you can hear the blower kick on and off like a torpedo heater on construction sites or like what you might have in a garage.
Mar 17, 2010 | Ovens
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at maugoro@yahoo.com
Feb 05, 2010 | Lincoln Ovens
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
Oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
Jan 13, 2009 | Lincoln Conveyor Oven - 1133-000-A
Lincoln Conveyor Oven - 1133-000-A Logo
531 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
