Question about Sewing Machines
My Kenmore (385 81710)
I have a Kenmore sewing machine..It works perfect but when the needle comes down to pick up the string from the bottom, it doesn't. Everything works fine but the string doesn't appear to be picked up by the needle..Any idea on what I could do? Thanks bro.
  • Desi123 Aug 19, 2008
    This happens with both Zig Zag and straght stitches. It doesn't stitch at all because the needle is not picking up the thread. Also this model has the front loading bobbin area. I have tried to put in a new needle, but fail to understand what threading is. I have lost the manual for this so I have no idea on how to thread. Any tutorial on threading would be greatly appreciated. Also I'm thinking the timing needs to be set because when I talked to someone else about this they said something about the timing. I Think this is a one piece machine am not sure. I will provide you with a link to what my machine looks like and maybe you can determine that yourself. Even if it is two piece I am not worried about breaking it. It already is broken so do not worry about that. I am ready to take any instructions by you as to how to open this and time it correctly. Thanks so much for your help again brother.
    PS: The link to the photo is :
    http://www.sewconsult.com/kenmore_instru...
Somehow the system has printed the reply twice, once as GUEST, and the original....if you are inclined to vote for my replies, please go to the bottom of the page for the correct reply.......strange behaviour by Fixya, not sure what went wrong.
Cheers
Martyn
Posted on Aug 19, 2008
OK, it is the timing (of the needle to the hook)......the page link you sent was very close to another that will give timing instructions for the 385 model, however I have a feeling you may have a newer model with the same number.
BTW, $8 for a User manual with service tips sounds like very good value.
Again I stress, if you have no way of undoing the base as a separate plate, and there is one joint running through the machine from handwheel to needleplate, take it to a repair shop.
If you can remove the base separately, the detailed instructions for timing are HERE
As a general guide to threading correctly, sewusa has ver good instructions for many models HERE.
Even if your particular machine is not included, you ought to get a very good idea of where the thread should go, as the principle is the same......
1. From Spool to a guide above Left....could be front or rear
2 Sometimes a 2nd guide on top front
3 Through Tension Unit
4 Up to Take up lever (moving arm)
5 Down towards needle
There may then be one or two more guides on the body and finally on the needle arm, before the needle itself.
Hope this is all of some use, let us know how you get on.
Cheers
Martyn
bargainbox.com.au
  • Sewing Machines Master
  • 1,388 Answers
When you say "it works fine" I guess you mean everything seems to move as it should, but the stitch is not being picked up.....so although working fine, it is not actually working at all........or is it intermittent, missing stitches...
Does it happen on straight, Zig zag or both ?
Does this model have a front or top loading bobbin ?
First thing, ensure the bobbin area and top tension are clean and clear of lint.
Change to a new needle and make sure the machine is threaded correctly
Can you form a stitch ?
If not, the timing will need to be looked at......are you or do you have a friend who is quite mechanical with basic small screwdrivers, allen keys etc ?
...if it has front, base, rear & side panels, it is far easier to get at with little risk of you doing damage.....BUT...
If it is a 2 piece plastic moulded body, you will likely break the retaining clips as you try to get it apart...best to take it to a repair shop where they ought to have the service manual to know where all the hidden screws and clips are.
There are several options for timing adjustment depending on the model, usually either near the handwheel or on the bottom shaft.
... this 385 (if that is what it is) model was never released in Australia, so it is difficult for me to know which Janome equvalent it would be (they are the same manufacturer however).
Can you find a photo of the model, (try a google images for Kenmore 385 and see if it is yours) or ask your local Janome shop if they can tell you, we can then look at further details for self timing.....but I stress again, if it is a 2 piece body, don't try it at home.
  • Hassy
    Hassy Aug 19, 2008
    Cheers
    Martyn
    bargainbox.com.au
SOURCE:
My kenmore 117-552 is vintage and I cant see how the hook times with the needle
same as on all machines
the needle is all the way down and is just starting to come back up at that point the hook should be at the eye or just about level with the eye of the needle
a bit further movement and the hook moves on to pick up the thread at the eye
Jul 09, 2017 | Kenmore Sewing Machines
I can not pick up the thread[string] from under the machine,both the strings on the needle and under the machine should be on top of the table to start sewing
If this is your first time sewing on a machine then:
Once you make sure the needle is threaded and the bobbin is sitting correctly in the bobbin casing, and you have installed and manipulated the thread according to your manufacturers instructions:.
Holding the end of the thread that you threaded through the needle, use the wheel (right hand side of the machine) and rotate it toward you pulling the thread that you are holding gently toward you.
The bobbin thread should give you some restriction and the end of the bobbin thread should have come through the hole in the needle plate (the metal plate that sits under the presser foot on the table of your machine.
Hope this has helped.
Jan 21, 2015 | Sewing Machines
How do I thread the singer 132k6 including the bobbin. is there a diagram i may see
Hope this sight will help if not you may have to contact the manufacturing company for owners manuaql
Jan 09, 2015 | Singer Sewing Machines
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
White Jeans Machine
I agree about the needle, took me forever to learn that one. I have a Kenmore Sewing Machine that would not pick up the bobbin thread every time I tried it after having it for a while. I would go to my other machine and use it. Then my daughter in law put in a new needle and it worked perfect until I tried to stitch a different type of material. It was then it clicked and I started researching needles for machines. You have to use the correct size needle for the material you are sewing or it will not work right. Also if your needle is dull or bent you will also have problems. Here is a site that may be helpful http://www.taunton.com/threads/pages/t00185.asp You can find more info by searching for "sewing machine needle information" Hope this helps.
Happy Sewer
Feb 11, 2008 | White Sewing 1766 Mechanical Sewing...
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
Mar 11, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
307 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
