Question about Belkin Computers & Internet
My belkin modem/wireless router model number F5D6833-4 will not always connect to the internet by wireless but operates ok from hard wired lead direct form a port ?
    President:
  • 2,961 Answers
Belkins antenna are not very good, put the router on a cupboard where the signal is not blocked surrounding it's area, and remember, doors, walls, floors, windows etc all reduce the signal strength.
If the signal gets below 24 MBPS it may not be able to connect you to the net
Posted on Aug 18, 2008
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Tip
Before posting your questions regarding routers , Please add the following...
Before posting your questions regarding routers , Please add the following information ..<br /><br />1 ) The model number of the product <br />2 ) The Name of your internet Service <br />3 ) The Name of the Modem <br />4 ) Number of computers & Devices that are to be connected to the network <br /><br />Example :<br /><br />Model no : F7D2301 ( Belkin Surf Wireless Router ) <br />ISP : Comcast <br />Modem : Arris <br /><br />Wired : 2 Desktops <br />Operating System : Windows - XP <br /><br />Wireless : 1 Laptop <br />Operating System : Vista <br /><br />Other : 1 IPhone <br /><br />======================================================<br /><br />If you provide all these information then it will help us a lot in giving you more accurate solutions <br /><br />Regards <br />Tom <br /><br /><br /><br />
on Dec 27, 2010 | Computers & Internet
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
