Question about Brother HL 5140 Laser Printer
Paper mine has paper light on but i added paper and now its just sitting there. tried turning off and restarting computers but is still showing red status light and paper light is on??? please help
I had a similar problem. I noticed that the paper tension on the paper tray wasn't set correctly. Needs to be tight. Once corrected it worked fine.
Posted on Oct 29, 2008
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
No power but ink & error/paper button blinking red
maybe need to replace a new cartridge or chick you ink if not empty
and din check inside your printer possible have a paper jump inside,,
or try to remove completely the printer driver using the (ad and remover program) how to this go to the start menu din control panel you can see the ad and remove program,, and click uninstall your printer driver and din restart your pc to take effect and din install gain,,
thank you i hope i can help you.. have a good day!!!!!!!!!
Jul 06, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Phaser 6110 - red light on, not printing
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Sep 11, 2008 | Canon PIXMA® MP530 All-In-One Printer
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Epson AccuLaser CX11NF
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Jan 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Mar 12, 2007 | HP LaserJet 6L Printer
Brother HL 5140 Laser Printer Logo
153 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
