Question about Yamaha RX-V520
Yamaha RX-V520 When power turns on I get a message "check speaker wires" then the power goes off.Now it won't power on at all.I don't have anything hooked up to it. Do you have any idea what this is or do you know of a service manual for this model.
    President:
  • Yamaha Master
  • 1,114 Answers
If you don't have any speaker wires hooked up to it and it won't turn on, the only thing left to check is the internal fuse. First, make sure it's unplugged from AC, then remove the top from the receiver, 6 or 7 small phillips head screws. At the back inside corner where the AC comes in there is either one or two fuses, check them. If you have a multimeter, dial it to resistance & sound (meaning when the two probes touch you will hear a tone) touch both ends of the fuse with the probes, if you get tone, fuse is good, if not, replace the fuse and all should be well. If you get tone, you've got either bad transistors or a bad power supply. Could be a 100-200 repair. Hope this helps
Posted on Jun 11, 2009
Yamaha RA-V1200 wont turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happened to me on RX-V592
Jan 16, 2013 | Yamaha RX-V1200 Receiver
Yamaha rx v473 system cuts off periodically - check speaker wires message comes on
You have a short in a speaker or speaker wire, or you are over-driving a speaker.
Jan 14, 2013 | Yamaha Audio Players & Recorders
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Jan 14, 2013 | Yamaha RX-V473 A/V Receiver Black
Yamaha RX-V595 receiver won't stay on
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
RX-V665 turns on for a second then turns off
don`t open it yet
Dec 13, 2012 | Yamaha RX-V665 Receiver
Rxv-520
Hello, it is worth checking that there is adequate ventillation around the unit, especially if it is in a cabinet. Also check that there is no dust clogging the vents on the unit. Another cause for overheating is using speakers that require far more power than your receiver can provide, or speakers with an ohm rating that is lower than the amplifier provides. Also, check to see if any wires to the speakers are crossing over as shorting will cause the amplifier to overheat and cut out. Hope this helps.
Jul 26, 2009 | Yamaha RX-V520
Power can not turn on for Yamaha RX-V520
If you can desolder the audio amplifier IC to check the device turn on,If the device turn on with the audio amplifier IC desoldered you need to change him.
Jun 12, 2009 | Yamaha HTR-5650 Receiver
Yamaha RX-V361 DVD cuts off w/ check SP cable message
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Jun 04, 2009 | Yamaha RX-V361 Home Theater Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V520 Logo
381 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
