2000 Mitsubishi Eclipse Logo
Anonymous Posted on Jun 08, 2011
I have a Mistubishi Eclipse 2000 GT. Yesterday I left work turn the AC on and 15 minutes later the ac light on the switch turn off, the fan turned off also. I check fuse # 15 30 amp for heater which are connected together and it melted in the fuse block. I tested the Circulation fan and it work just fine. What could cause the problem?
  • Anonymous Jun 08, 2011
    What is in the circuit of this specific fuse? (fuse # 15) I tested the circulating fan and it work fine. what else can I test
Anonymous
Level 2:
Sergeant:
  • Expert 207 Answers
  • Posted on Jun 08, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
207
Questions
Helped
76884
Points
545
It sounds like you got a short circuit somewhere, you can try replacing the fuses and see if it happens again.
  • 3 more comments
    Your manual should tell you what is on each fuse, just look in the index for fuses.
    I would love to have this book but I don't do you have any way for me to get this book
    Check with the dealer, they can get you a replacement, regardless you should replace the fuse and see if it works. That big if a fuse is probably the compressor, which would explain the lack of ac.
    the deal is the fuse blowed so bad that the fuse block need to be replace. I can't even put a new fuse there.When i pulled the old fuse out the female proung got out with it (welded) I'm scare to just replace the fuse block with a salvage one, test it and the same problem happen again.
    Gotcha, since I don't have access to the owners manual I'm gonna back out of this one, if you try calling the dealership, sometimes they will help you out over the phone, don't just ask them to solve the problem but ask specific questions like what other things are on fuse number 15. I still think you have a short in your cooling system electronics, but they can be tough to find. If you don't want to spend much money, try putting in the junk yard fuse box, the short might have been inside the old box, which would explain the melted fuse.
2answers
Ac only works on low
correct my did the same thing replace the switch
1helpful
AC and Heater does not work on 2000 Eclipse GT? It does not blow any air at all any suggestions?
Have the fan control switch replaced. Sometimes it gets stripped. It might seems like it is turning, when it really never engages at all.
Golf 2000 is my car Recently I changed my Waterpump, TB and FCM. I find my AC sometimes works good, but other time just blow warm (compressor doesn;t comes on). Yesterday after adding two cans of...
firstly i think you have overcharged the Ac system as the most it should hold is 650 grms for this system on this model ,if too much gas it will click in and out and slow the engine down ,as for the gauge readings then renew the sensor its on the housing at the front in the plastic housing ,depending on year and model this is where most are ,but some later models have a sensor at the back of the head left side from front
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
2helpful
AC Problem in my mitsubishi eclipse spyder 2002 GT
Sounds like the cooling fan motor,or motors,are not working.Check the relays,and fuses for the cooling fans.If the ac is on,look to see if the cooling fan,or fans come on.If they do ,then most likely have an enternal ac system problem.The expansion valve is the most likely problem,or possible,the dryer.Have the ac system checked to see if it is low,or if the low side is going into a vacuum,if it is going into a vacuum,replace the expansion valve.First check to see if the cooling fans are working with ac on.If I can help,let me know.>>>[email protected]
1helpful
2answers
2000 Buick Regal
Check plug in on ignition switch,and if it is good ,replace the switch.
Ac light stays on only on no. 1,goes off on no. 2,3,4,
new switch i thing thats all if it is a 2000 and not a later one
3helpful
2answers
AC & Rear wiper switch button indicator lights blink
The procedure for re-setting the HVAC control panel on a 1998 Dodge Grand Caravan follows:
With ignition on but not running
1. turn knob to air vents
2. turn fan knob to ON
3. temperature setting on COLD (2X) {I have dual temp controls}
4. hold top(rear wiper) and bottom (rear wiper with wash) buttons pressing down together until all the buttons cycle through (this will require 1 to 2 minutes of continuous pressing)
I learned this from a very helpful local Dodge service adviser
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
