Question about Belkin Computers & Internet
Belkin F5D7630-4A ADSL broadband connection problems. Hello, The computer recognises the modem router and I can access the setup wizard. It goes through the connection process apparently seemlessly, but will not connect to the internet. All of the indicators light up as expected except for the adsl Data indicator. Your help here would be greatly appreciated. Many thanks Kenny
    President:
  • 2,961 Answers
Check you have typed in the correct password and username for your isp adsl connection
Posted on Aug 18, 2008
Belkin N Router does not recognise PPPoA connection type
First reset the router by pressing the reset button for 10 seconds while power is ON and then after that run again the setup , just to give you a clue which one to choose for the internet setup, if you use Cable internet select Dynamic and if you use DSL internet set it to PPPoE and provide your email and password from your DSL company...
Dec 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Computers & Internet Logo
124 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
