Question about HP LaserJet 3055 All-In-One Printer
Hp laser jet 3055
Was sending a fax this morning stopped in middle of fax i cancel the fax and machine froze up turned off and back on and now on the the display screen all it will do is show hewlett-packard >>>>>>>> and will do nothing else and if i try to print anything it show i have no connection i have turn off unplug everything reconnected eveything and turn on and even rebooted my computer nothing helps please help me
  • Anonymous Dec 29, 2008
    Thank you for this information. It looks like we have an issue with our formatter since the printer won't boot beyond >>>>loading the firmware.
  • HammerAuto Feb 04, 2009
    My HP 3055 just quit responding to any buttons pushed and says Hewlett-Packard >> >>. I tried calling technical support and the machine would not respond to the * and 5 keys pressed as the machine is turned on. Is it worth getting a board replaced or should I get a new all-in-one?
  • 138 Answers
You have a formatter issue (motherboard) on the printer. Sounds like you took a surge possably through your telephone line.
Here's a couple things to try and re-initialize the machine.
Soft Reset: Press "Menu", then press * and # simultaniously to enter the developer menu section. Press the "> or < until until REINTFFS is displayed on the second line of the display. Press the "Check button". The machine will go through a series of checks and flash different things. About 2 to 2.5 minutes later the machine will return to ready.
If that doesn't fix it, here's the next more aggressive reset but caution as this will reset all your settings and you will have to reset up everything (language, phone numbers, country code etc..) after using.
Super NVRAM Ret:
Turn off machine, Press and hold down * and 5 while turning on machine. Continue hold down throughout the power up sequence. When PERMANENT STORAGE INT is deplayed on the display, release the buttons. When prompted, set the language and telecom region.
To set the language and telecomm region, the machine will prompt for them when they have been erased. Simply use the > or < until its correct for your language and then press the "check" button. Same process for the region. Once both have been set the machine should come to READY.
If neither of the above works, you will need a professional tech to resolve the issue and possably replace the formatter board.
Hope that helps you.
Posted on Aug 26, 2008
My home HP laser jet 3055 machine is not connecting
Hi:
Make sure that it is set to Auto Receive not Manual Receive. Also make sure the the telephone line cord is plugged into the Line jack not the Tel jack on the back of the fax machine.
Jul 19, 2012 | HP Deskjet 3050 Wireless All-in-One Inkjet...
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
How can I clear my fax memory hp laser jet 3055
Hello !
You can clear the memory by doing an NvRam or hard reset
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
May 14, 2010 | Canon L120 Fax Laser Printer
HP Laser Jet 3055 will not install because of newer verison
click this link for Vista - http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=2093
scroll down the page and goto the Software section - click one of the three download button after checking the region (Asia Pacific/ Eastern Europe/ North america)
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
Memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
Nov 12, 2008 | HP LaserJet 3055 All-In-One Printer
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
Hp laser jet 3055
I have checked all my connections and I can't send a fax. It comes back no answer but I know the problem is on our end
Sep 12, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
1,820 people viewed this question
Seeker5211
Seeker5211
