Question about Tappan TGF320 Gas Kitchen Range
Tappan oven does not heat
When the temperature is set, it reverts to zero. Everything else works, including the top burners
  • 1 more comment
  • Anonymous Aug 24, 2008
    oven will not heat up when you dail the control ingition lights but thats it
  • forester1 Sep 07, 2008
    Oven somes times takes to long to ignite and builds up gas and then "popps" before inginiting but sometimes it starts and no gas smell, no ingition sound. Model 30 series purchased 1992
  • Anonymous Oct 02, 2008
    all burners work the smell of gas is there but the oven will not light.
  • 943 Answers
Hi thanks for the question all these oven gas not igniting mostly hase to do with igniter thanks the appliance doc
Posted on Sep 16, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
My Tappan gas oven will heat up to temperature when first started but will not maintain temperature after that. The burner will not re-ignite. If I lower the temperature to the off position then put back...
thermo couple may be defective. Disconnect oven, look inside oven it will be a 2-4 inch tube looking brass type metal. use ohm meter check continuity if non then most likely its defective. other then that it may be the control board.
Sep 11, 2017 | Tappan Kitchen Range
Tappan 30-3822 will not bake. Top burners and broiler work, oven will not fire.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Tappan 30IN ELEC IGNa Oven
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven won't work
that apart that glows red hot is probably bad, most likely bad. it should glow white hot and ignite the oven in under 1 min form time it starts glowing, part number 12400035 should help you out comes with everything you need, including instructions
Nov 25, 2008 | Tappan Kitchen Ranges
Tappen model TGO356BCW top oven
replace the igintor. its not working properly. no doubt you have a bad ignitor
Mar 15, 2008 | Tappan TGF320 Gas Kitchen Range
Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Dec 21, 2007 | Kitchen Ranges
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
