Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
Answer:
The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Routing" message may appear on your device for the following reasons:
The GPS device is
The maps on the GPS
If you see a "Can't
on the GPS device
Normal
0
false
false
false
font-size:10.0pt;
The GPS device is
The maps on the GPS
If you see a "Can't
on the GPS device
Normal
0
false
false
false
font-size:10.0pt;
Routing" message may appear for the following reasons: The GPS device is
missing it's unlock code The maps on the GPS
device have been disabled To determine the cause of the message, touch the
If you see a "Can't
on the GPS device
You need to unlock the unit. I had the same problem with one that I have. Try this:
The NoDetailedMapsFound That Support Routing message could be due to the following reasons:
To determine the cause of the message, touch the screen until the message NoDetailedMapsFound That Support Routing disappears.
If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
Plug your Garmin device into the USB port.
Double-Click on My Computer or Computer located on the desktop.
Double-Click on the Garmin or nüvi drive.
Double-Click on the Garmin folder.
Right-Click in a blank space in this window.
Move your mouse over the word New.
Select Text Document.
Press Enter / Return on your keyboard.
Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
Select File.
Select Save As.
Change the Save As Type to All Files.
Type gmapprom.unl in all lower-case letters for the File name.
Select Save.
Close the Notepad window.
Delete the New Text Document file.
Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
Select File.
Select Save As.
Type gmapprom1.unl in all lower-case letters for the File name.
Select Save.
Enabling maps on the GPS device:
Touch the wrench icon on the Where to/View map screen.
Touch Settings.
Touch Map.
Touch Map Info.
Select the checkbox next to the maps to be enabled on the device.
Try three things: 1)Do a reset 2)Do a Master reset 3)Try doing a full software update by getting the free program from Garmin called WebUpdater.
Normal
0
false
false
false
font-size:10.0pt;
To download the latest unit
software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin
website, perform all future software updates from your computer. Simply connect
your compatible Garmin device to your computer, then run WebUpdater from your
computer's "Start Menu" by selecting "Start",
"Programs", "Garmin", and finally "WebUpdater"
Normal
0
false
false
false
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
A file is probably missing or corrupt in your Nuvi. You can call Garmin at 1-800-800-1020 and their software techs can remotely connect to your computer to check the files on your GPS to see if they are ok or not. There is a method where they create a file with your 25 digit unlock code in a certain directory to unlock the maps, but that information can only be received from Garmin.
