Question about Nintendo DS Lite Console
DS Lite just died but power light still on
My daughter was half way through a game and it just went blank, no picture on top and bottom screen but the green power light is on, tried charging and you can turn it on and off but only green light is on. Help please
  • 1 more comment
  • ED STOKES Aug 22, 2008
    me to
  • Anonymous Sep 06, 2008
    top screen went out
  • dead4ngel Jan 13, 2009
    that happend to me as well. i thought it was the led. but when i showed it to my dad ( a pro electrician lol) he said that it isnt the led. it is the wire that runs the power to the 2 screens. cos today when i tried to turn my ds on, it came on. then i turned it off, and i was back to square 1. i am gona try to get it fixed through nintendo's warranty. wish me luck. hope this info helps.
    Problem Solver:
  • 9 Answers
Before i answer how many times had you charged since you bought the ds
Posted on Oct 18, 2008
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
When i turn on my DS the top screen is blank then it turns white and stays like that, i don;t know what's wrong
If your booting to a GBA game, there us a setting in the machine BIOS to tells it to use the top or bottom screen. You can access it by taking out the games and booting the unit.
If your booting a DS game, it should display on both. If not, it is possible a wire has come loose on the display (or the screen went bad).
You can try and check for the wire yourself or take it to a repair shop. If you bought it recently call Nintendo.
Nov 01, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Ds lite bottom screen
Could be the back light.Probably need to replace it.They are reasonably cheap.
Jul 01, 2008 | Nintendo DS Lite Console
My daughter's nintendo ds has a frozen screen even though we tried to recalibrate in the usual way
hi I'm Adriana,
Here is what you can do, if your screen is completely white on both top and bottom just close it and let it die when you see the the green or blue lite is red let it die then after maybe 2 days you can recharge it with the dsi or ds lite charger. I advise you that if this process does not work take it to a game store and trade it in for another ds
Thank you i hope this information is helpful
Jun 23, 2008 | Video Game Consoles & Games
Ds Lite bottom screen flashes then shuts down
Not necessarily. When the cable to my top screen became partially torn, it prevented the DS from powering up. Instead, the green light briefly lit up and then went out and the machine stayed off. I can only presume that feedback is required from the screen. As for the bottom screen, I'm unsure of how the DS behaves when the screen or cable is damaged.
Hope this helps.
Jun 07, 2008 | Nintendo DS Lite Console
Nintendo Ds Lite White Screen
Try cleaning the game. If you look at it in the light you may find it has some scratches or something. You see my brother has that! Love Tamsin
Mar 15, 2008 | Nintendo DS Lite Console
Cant play any game
Is this the top screen or the bottom screen? The top isn't meant to react to the stylus.
Jan 04, 2008 | Nintendo DS Lite Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
255 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
