Question about Dryers
Zanussi tce 7127w condenser dryer.keep getting the wrong program selected light and buzzer.It will occasionally start to dry clothes for about 10 mins and then buzz or more often it will sound as if the pump is filling the reservoir and stops and about 30 seconds later the light and buzzer willsound indicating that rhe wrong program has been selected.I have tried every program, but none of them work
  • 1 more comment
  • Anonymous Sep 02, 2008
    My dryer has just started with the exact same problem, starts up, sounds like pump is doing something, turns for about 10 mins, then stops with end of program light flashing and buzzer sounding.
    I've tried everything I can think of, cleaned it all out as well in case it was sensors.
    I bought my dryer in April 2006.
  • mtloughran Nov 25, 2008
    I have also tried everything I can think off ... doesn't seem to be a pattern ... sometimes pulling out the dryer and freeing up hoses makes a difference ... sometimes not. It's driving me crazy.
  • taz_uk Apr 17, 2009
    I have exactly the same problem as "Guest" stated on Sep 02, 2008. Please help!!
SOURCE:
catriver
  • 878 Answers
SOURCE: dryer stopped working
plumber, pop the top on the dryer by pushing on the two clips just under the top on each side. In the back you will see the heater. You want to check the high limit thermostat (this one sits on the top side of the heater) and the thermal fuse (sits on the side about 4 inches down. Unplug the dryer and check them with a meter. If either shows open (no continuity) replace them. Make sure your venting is not clogged up and the heater is not grounded or fractured. Part number for the high limit is 53-0771 and for the thermal fuse is LA-1053. Check these first...Catriver...post back. Unable to find your exact model, but I do have cye4000ayw. parts should be the same.
Posted on Oct 12, 2006
SOURCE: my zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Posted on Mar 06, 2007
SOURCE: my dryer stops drying after 10 min. All the lights
My dryer does the same thing. Additionally, it is not heating what so ever. Clothes are cool and damp, and heating vents at back of dryer are cold to the touch.
Posted on May 12, 2010
SOURCE: Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
Posted on May 17, 2010
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Posted on Jun 13, 2010
My Zanussi TCE7124W is not running cycles properly and the clothes are still wet at the end of a run
The filters are clogged.
• The condenser is clogged.
• The water reservoir is full.
• The selected cycle is not suitable for the laundry.
• Insufficient drying time.
• The laundry has not been spun properly.
• The low-temperature function selected.
• Excessive laundry load.
• The dryer is not correctly installed.
Also, check the heater elements.
For the movement, check the drive belt has become worn or snapped. To test your tumble dryer's drive belt, we recommend you manually spin the drum. If it is stiff and difficult to move, the drive belt is ok, if it is easy to move, there's a good chance the drive belt is the fault.
Nov 02, 2017 | Zanussi Washing Machines
Hope this helps.
May 14, 2010 | Dryers
Hope this helps.
Mar 25, 2010 | Dryers
TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Feb 17, 2010 | Zanussi Dryers
Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Nov 06, 2009 | Dryers
Zanussi TCE 7276W taking ages to dry.
make sure your dryer vent is not gloged all the way to the outside first befor you do anything else,take a air hose and make sure you have ventilation. hope this helps
Jun 12, 2009 | Dryers
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
My zannusi dryer is will not dry clothes on hot setting
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
