Question about Maytag Dishwashers
Top spray bar had stopped spraying - can open door quickly and the bar is not turning -- also can put bar in one place and run machine, when you open door bar is still in exact same place.
  • mikecoldiron Aug 19, 2008
    p.s. to the note above this is a Model MDB-7100 AWB Jetclean Plus - about 4 years old
    Thanks Again for the Help
  • 487 Answers
Means either water line from pump to upper bar is clogged or pump is broken. My guess is the first
Posted on Aug 18, 2008
Smeg dose not takein water
Is the dispenser door opening.....f not the the dispenser is faulty
It the dispenser is opening but the product dose remain plugged in the cavity, the top wash arm may not be turning.
Clean out all of the particles blocking the top spray arm holes and spin the arm to ensure ti turns freely.
Also check that there aren't any items placed it the top rack that could stop the arm from rotating freely.
Product not coming out of the dispenser id usually always due to the top spray arm . if it is blocked with particles you may not have been cleaning the filter in the sump properly and 'bits' of food ate passing th filter, Make sure the filter in the sump is well firmly in place.
The last important point is to always run the machine at 60 degrees or more You need temperature to do the job properly.
Nov 15, 2014 | Smeg Dishwashers
Ignis adl349/a seems to fill and drain ok but stops after 2/3 mins and beeps 4 times
What this actually signifies is that there is a problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an uncommon problem, but once cleaned, run the machine on a hottest wash, hope it clears the problem.
Check inside for the hose (see if in place or off the top spray bar)to check whether water is going into the spray bars and spray arms work well. ----------
The 5 flashes indicate a spray. Pump fault, either blocked or motor fault.
Press and hold the start button until the light goes out.
Select a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
Feb 16, 2011 | GE Built-In Dishwashera Oven
My dishwasher has stopped cleaning plates properly. It makes everything wet but at the end of the cycle the detergent block is half dissolved at the bottom. I have just run a cycle and opened the door...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Mar 27, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Water leaks out below the control panel and runs down the door
your internal spray might be stuck
put the spray arm in a position you know
turn the machine on for few second open the door see if it turn
do the same to the upper unit(if you got)
when the spray arm spray water on the door then you got this kind of leack
Dec 31, 2009 | Kenmore 13732 / 13734 / 13739 Dishwasher
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
Water leaking through vent in door
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Oct 15, 2009 | Roper RAS6233KQ Top Load Washer
Powdered Soap Dispenser
The soap door doesn't open fully on that model, and usually flips fully open as you open the dishwasher door.
It relies on the top spray arm turning to 'wash' the soap out of the drawer - and that will be the problem.The spray arm isn't turning.
Check the spray arm for blocked jets at the very end - use a pin to clear them out, or replace them - check both spray arms. Make sure the spray arm rotates freely also.
Remember the dishwasher isn't a garbage disposal unit - remove food deposits from plates etc before loading the machine. Run a dishwasher cleaner through the machine now and then. Food like pasta, or fruit pips often get carried to the end of spray arms and block them.
If using a 30 min rapid wash program ONLY and dishwasher tablets, put the tab in the cutlery basket as it wont have time to dissolve fully if you put it in the dispenser.
Feb 02, 2018 | General Electric Profile PDW7980NSS...
GE Profile PDW9880 rinse arms don't spin
Check spray arms again to see if the very end jet is blocked - or if the spray arm has split? the end jet is angled and that's what turns the spray arm. If you can't clear the blockage, you may need new spray arms. Or try putting the spray arms into a known position, and run the machine - see if they have moved.
The pump may be running, but are you sure it's pumping? sometimes bits of broken glass or pot get into the pump chamber and strip the rotor vanes off. Try setting the machine to wash, make sure you can hear the pump run, then quickly open the dishwasher door to check the flow. If you get a face full of hot soapy water then everything is ok!
Remember that a dishwasher isn't a garbage disposal unit - and remove all food scraps from plates before putting them in the machine. That's what often blocks spray arm jets.
Jan 30, 2018 | GE 24 in. Profile PDW9880JSS Built-in...
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
141 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
