A properly installed, (nintendo logo on cord facing top of console), used for the first time, DCconnector plug cannot be removed from it's jack in the back of the console by a 250 lb. man. using substantial pressure. Any ideas?
To fix this you might have to open the shell to get to the two pines that hold it, but try this slightly twist the plug and down and out at the same time
Is the light blinking while you wiggle the plug? If so there are one of two problems one is that your cord is broke. Or two the jack on your DS is broken. Try replacing the cord first as it is cheaper.
First thing to go is try a different television and a different video cable if still no picture is displayed on television (screen is blank) You seem to have a problem with the video output from your nintendo wii.
NO PICTURE 1 Turn your television to the correct video input channel. For many televisions, you can press the "Input" button until you see the Wii start up screen.
2 Ensure the power cord is securely plugged into the DC jack on the Wii and the opposite end is plugged into a working electrical outlet. Press the "Power" button on the Wii and wait for the indicator light to turn blue.
3 Secure all of the Wii component cables to the "Video In" jacks on the television. In addition, make sure the opposite end of the wire is fully plugged into the Wii.
What color is the power light when the system shuts off?
Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
Blue: If the power light is blue when the
system turns off, then there appears to be a problem with the system and
it will need to be repaired.
If the orange recharge indicator light blinks while the system is
plugged in and charging, then it is likely that the battery is not
installed properly.
If you have ensured that the battery is installed properly but the orange
light still blinks, check to make sure that the battery is a licensed
by Nintendo. The only licensed Nintendo DSi battery will have the model
number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will
display Nintendo's logo. Call 1-800-255-3700 if you still need help.
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
The dc jack where you plug in the ac adaptor is worn out which is why it is chipping and also why you can't make a good enough connection for the ac adaptor so you can turn on the Super Nintendo.
What needs to happen is your SNES needs to have the old dc jack taken off and a new one soldered on.
If you can find another broken SNES that has a good working dc jack then take if off of that one and solder it onto yours and your SNES will work like new.
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
