Question about Brother FAX-2920 Plain Paper Laser
Brother Intellifax 2920 / How to reset Drum Life ?
Hi two questions actually:
1) How to reset the drum life % on the Machine Setup menu
2) I seem tobe changing the drum 3-4x's a year, any suggestions?
Thanks, ALR
  • dannyjames_1 Nov 24, 2008
    I just replaced the drum and toner cartridge. How do I get rid of the message "change drum soon"?
    New Friend:
  • 20 Answers
1.Open the front cover.
2.Press the options key on the control panel. The display will show
3.Press 1 to reset the drum count.
4.Close the front cover.
Posted on Aug 14, 2009
  • blueslondon Nov 22, 2010
    Superb! Many, many thank yous.
I have ricoh fax machine model 1190l,it is showing to replace the drum but the print quality is very good how can i remove the indication without changing the drum?
Posted on Feb 08, 2012
We have a Brother Intelli2820 and the paper keeps wrinkling on received faxes, any solution?
Posted on Mar 25, 2010
The machine reset's the drumlife it self, most of the new fax/copy machines's does it.
The drum unit you change mostly once a year, 3-4 times a year it's very much. Also never open the new drum unit, until you have removed the old unit. The drum unit dosent like the sun/light, it may shorten the drum unit's life
Posted on Dec 19, 2008
Reset Drum life MFC 9440CN
Not sure if this Brothers is the same but normally open front were you install drum and toner, machine on depress, menu button or clear button, display will show 1 or 2 to tell
you to reset drum count.. hope this works
Mar 04, 2016 | Brother MFC Office Equipment & Supplies
Ford explorer trac 2007 change the oil and filter and now have a wrench light on ,how resolve the problem
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye:
1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET
2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK
3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW
4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL
5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100%
6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows:
1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK
2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL
3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100%
4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
Nov 03, 2013 | 2006 Ford Explorer
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
I put in a new drum and the 7020 still reads "Change Drum Soon"
Open the front door and press the options ar menu key, if it doesn't ask you if it's a new drum, then press 3 and 9 together and scroll thru the items to reset and reset the drum.
Dec 22, 2009 | Brother DCP-7020 All-In-One Laser Printer
Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Jun 27, 2009 | Brother MFC-9840CDW Laser Printer
Replacement or buying a new one?.
Hi, this seems to be lamp only, go the menu setup and press service info : then you get the lamp hours used if it is more then 1500 hrs you must change the lamp if less, try cleaning filter then reset the lamp again. if problem persist. lamp has to be changed.
Jan 27, 2009 | InFocus IN72 Multimedia Projector
How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Jan 09, 2009 | Brother DCP 7010 Multifunction Laser...
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Dum problem
1. Open the drum/toner door on the front of the machine.
2. After the beeping stops, press the button on the line of buttons that says Menue Left arrow set richt arrow and clear button.
3. The menu will say replace drum? 1. yes 2. No
Press the number 1 on the number pad and close front door.
Oct 19, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother FAX-2920 Plain Paper Laser Logo
7,446 people viewed this question
James Cagle
James Cagle
Jim Keysor
