I have a tshiba 42inch rear screen projector tv and i need to replace the black screen that sits infront of the clear screen. where will i find this product?
  • 20 Answers
You should be able to get what you want through your local appliance store,,or if no luck with that you may have to contact a toshiba distributor
Posted on Dec 01, 2008
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
I did something wrong.....
Windex is not the best cleaner. Bed and Bath Beyond has a very good NON-Streak class cleaner that I tell my customers to use. The best solution is NOT to Spray directly onto the TV Screen. Remember the glass is only delivering the picture from an RGB projection unit sitting inside the enclosure. It is not the electronic projector and the screen is separate. It can be replaced if damaged; however I believe it is only streaked and needs proper cleansing. If you get the new cleaner, spray the solution onto a soft cloth and wipe the exterior screen. Promptly wipe it dry and if you need to do this a few times, eventually you will get the glass clear and enjoy the show.
Dec 18, 2013 | Panasonic Televison & Video
Easy touch 42inch lcd tv black screen
replace power supply and mainboard
Jan 21, 2013 | Televison & Video
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
A black rectangle showing in the middle of the screen this appeared suddenly
this sounds like screen burn with rear projection and plasma when a picture is left sitting still on the screen sometimes it will burn in to the screen rendering it useless i left my ps3 paused on my old tv then when i changed to bbc one it still had a faint call of duty pause screen in the back it can vary from things like that to logos to your black rectangle the only way of repair is by replacing the screen all toghether i would advise you to just take the screen off and start using the tv as a projector if you cant find a screen it is only a bit of ribbed plastic but very hard part to find
Feb 16, 2011 | Toshiba 46HX83 46 in. Rear Projection...
I put a new lamp in last week. on the screen it ask me push enter so i did and the sentence went off the screen and the tv has worked good. now it is asking the same thing and i push enter and the...
reset the TV set, infront of your TV where the LED lights are there is a small reset botton that you can push with the tip of a pencil ot pen hold this botton down for 10-15 seconds then unplug the TV set and let it sit for about a 1 or 2 hours
then turn it back on it should work and if the TV still turns of after a few minutes you might have
a ballast issue sence you already replaced the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba projector tv with cracked screen
WHERE DID YOU GET YOUR REPLACEMENT SCREEN FOR YOUR TV? I DESPERATELY NEED ONE.
PLEASE EMAIL ME AT <quickquestions@hotmail.com>
THANK YOU
Dec 26, 2009 | Toshiba Televison & Video
My tv screen on my samsung rear screen projector has gone blank(black screen although sound is still clear.
Do you hear a motor spin up and a clicking sound as the tv is first turned on, if yes, You need to look behind the set and see if the lamp is still illuminated, if not replace lamp. Good luck.
Jul 07, 2009 | Samsung Televison & Video
The colour on my samsung rear projector out of line how do i fix
Sounds like the convergence chip needs to be replaced. You need a good soldering gun and a steady hand. i believe the kits come with full detailed instructions on replacing the chip.
you can get the kit at www.tvrepairkits.com
Apr 24, 2009 | Samsung HCM4216W 42" Rear Projection...
How you cann repair a broken plasma tv with out replacement parts
The tv plays fine my sreen is cracked on my Sony 42inch screen can some one help me.
May 13, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
