Question about Whirlpool LER4634J Electric Dryer
Dryer belt replacement
I do not understand how to place the bracket for the dryer belt, it has no pulley
  • Anonymous Oct 07, 2008
    how do you replace a dryer belt
  • 54 Answers
Here is a diagram for all different idler brackets:
http://applianceguru.com/dryers/belt-config.jpg
Heres step by step instructions : http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=104&osCsid=04e7ee4c310415fa34843011f244f284
Here is an exploded view of your exact model and your part number is 32: http://www.partselect.com/Schematics/Whirlpool/HYQBHAKC.gif
Posted on Aug 18, 2008
SOURCE:
Kenmore 110.731102100 Gas Dryer replace belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Kenmore Dryers
Roper gas dryer wont tumble
Jun 03, 2012 | Roper Dryers
How to replace a belt on a dryer
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
Belt is loose around the dryer drum
May 19, 2012 | Roper Dryers
How to install a dryer belt
Feb 11, 2012 | Kenmore Dryers
Can you give me information on how to replace the belt in the dryer.
From back of dryer remove access door to disconnect belt from motor & tensioner.(remember how belt was placed on tensioner & motor pulley) You must remove dryer front panel ( look for 2 screws at bottom of front panel) Pull out from botton of front panel to remove, exposing drum end retainer brackets, remove brackets, allowing access to drum. Slide old belt off & new one on.
Feb 13, 2011 | Dryers
REPLACING BELT
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I have disassembled my Whirlpool dryer and discovered the belt had come off. There was a part the is not secured fully to the dryer that has a wheel that appears to run against the belt, yet this piece...
there are 2 slots in base just under motor pulley the bracket fit into the the bracket will curve to left when installed properly..place belt around drum grooved side down..double belt at bottom and push through opening in bracket and around motor pulley roller on bracket will ride on top side of belt keeping tension on it
Aug 19, 2008 | Whirlpool Dryers
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
419 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
