I need to delete windows messenger off my mums laptop. I have tried add/remove programs but it isn't giving me the option to remove. I need an easy way to remove as it needs deleted asap.
    Genius:
  • 1,689 Answers
The link below will give you the instructions on how to delete or manipulate Windows messenger in your PC.
http://www.pchell.com/support/removemessenger.shtml
if you have other questions please let me know and i will try my best to answer it.
Posted on Aug 18, 2008
How to remove msn
I take it that you don't wish to use MSN for internet access. You can delete it from your network connections window.
Then you will have to set up a connection that will use either dial-up or some form of high-speed connection. That will become your default connection.
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
Please help me either fix yahoo messenger or tell me how to get rid of it completely i tried to uninstall it it wont let me
if you cant remove it from add remove programs, you can try to use window installer cleanup utility. you can download it from this website : http://support.microsoft.com/kb/290301 . if it doesnt work you can use CCleaner and download it from this website : http://www.filehippo.com/download_ccleaner/ . to run windows installer clean up utility,after you have successfully installed it on your computer, it should show up on all programs after clicking start button. now you cna look for yahoo mesenger and click delete. if you want to use ccleaner here is a screenshot of the tools window, http://www.ccleaner.com/screenshots/tools-uninstaller
look for yahoo messenger and click delete entry. after using ccleaner, restart the computer and uninstall it as well using add remove programs. you can also uninstall yahoo messenger following this path: my computer/local disk c/program files/yahoo/ and then delete the folder that say messenger.
Sep 26, 2009 | Yahoo Messenger
Error code 8007007
This error indicates a problem with Messenger on your machine, not a problem with the service.
You may be able to quickly solve the problem by installing the following components simply by downloading the MSI files linked following and just running them to install:
> http://messenger.jonathankay.com/redir/w3rc/dw20.asp
> http://messenger.jonathankay.com/redir/w3rc/msvcrt.asp
> http://messenger.jonathankay.com/redir/w3qfe/contacts.asp
After these are installed, try Messenger again.
Aug 25, 2009 | Microsoft Windows Live Messanger
Cant uninstal msn
Hi Buddy,
you need to go into Add/Remove programs, and remove any Program Associated With Windows Live, And Windows Messenger/Msn.
Sometimes you,ll only remove part of the Programs, not All.
Hope this Helps you Out.
Regards Mike.
Jan 23, 2009 | Toshiba Satellite A60 Notebook
I cannot uninstall my yahoo messenger
first kill the process related to messenger in taskmanager
then uninstall from All programs.
otherwise simply remove from control panel(Add/Remove programs)
..vijay
Jan 17, 2009 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
Incorrect line parameters winos installer v 2.00.26.00.0
Dec 09, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Problem with new email notification link on IM!
There are 5 things that you must check:
1. At the start menu click on control panel>add or remove programs>set programs and access defaults>custom (there are 3 to chose from): check e-mail
2. At the tools menu click on internet options>programs: check e-mail
3. At the task-bar right click>properties>start menu>customize: check e-mail
4. At the start menu click on control panel>add or remove programs>change or remove programs: check if windows messenger 8.1 is still there 9.0 might need to be repaired. It will say change or remove.
5. At the start menu click on control panel> windows firewall>add a program: add windows 9.0 and make sure 8.1 has been deleted
Nov 06, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
