Computers & Internet Logo
Posted on Jun 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 31 always appear on the dialog box
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 98 Answers
  • Posted on Jun 07, 2011
Anonymous
Expert
Level 2:
Filmmaker:
Answers
98
Questions
0
Helped
24123
Points
326
Try to check this Code 31 Resolution from this page
http://pcsupport.about.com/od/findbyerrormessage/a/code-31-error.htm
I hope this information will be helpful. Thank you for using FixYa!
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Samsung 6000/6500 internet browser
The 6500 and above has a web browser in the Smart Hub else:
Using Your TV as a Computer (PC) Display
Setting Up Your PC Software (Based on Windows XP)
Depending on the version of Windows and the video card, the actual screens on your
PC may differ in which case the same basic set-up information will almost always be
applied. (If not, contact your computer manufacturer or Samsung Dealer.)
1. Click on "Control Panel" on the Windows start menu.
2. Click on "Appearance and Themes" in the "Control Panel" window and a display
dialog-box will appear.
3. Click on "Display" and a display dialog box will appear.
4. Navigate to the "Settings" tab on the display dialog-box.
The correct size setting (resolution) [Optimum: 1920 X 1080 pixels]
If a vertical-frequency option exists on your display settings dialog box, the correct value is "60" or "60 Hz". Otherwise, just click "OK" and exit the dialog box.
Error code 31 appears when i tried to update driver software
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
This particular error comes into sight when the device driver is active and used by another device in the system. This will disapprove the new device to function correctly.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers. Free registry scan Select your operating system: THE SOLUTIONResolve the error in the Properties tab. Use Device Manager to redetect the device. If the driver is not correctly operational, update the driver.
2answers
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Sound controller won't install
MORE INFORMATIONThis section lists the error codes and possible resolutions for the error codes.... loadTOCNode(1, 'moreinformation'); This section lists the error codes and possible resolutions for the error codes. The error codes are listed in numeric order.
Before you continue, make sure that you have the error code available. You can view the error code in the device Properties dialog box available in Device Manager. You can also resolve many of the errors within Device Manager.
To start troubleshooting, follow these steps:
  1. Make sure that Device Manager is open, and that the device that has the problem is selected. You can perform some recommended resolutions through Device Manager.
    1. Right-click My Computer, and then click Properties.
    2. Select the Hardware tab, and then click Device Manager.
    3. Double-click the device type that has the problem. For example, if you have problems with your modem, double-click Modems to see the devices in that category.
      A list of devices appears. If a device has problems, the device has a red exclamation point next to it. If a device is unknown (usually because of missing drivers), the device has a yellow question mark next to it.
    4. Right-click the device that has the problem, and then click Properties. This opens the device Properties dialog box. You can see the error code in the Device status area of this dialog box.
  2. Use the Troubleshooting Wizard, if it is available, to help you diagnose and resolve your problem.
    1. On the device Properties dialog box, click the General tab.
    2. Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide. If the Troubleshooting Wizard is not available, go to step 3.
    3. Follow the resolution steps provided by the wizard to resolve the problem.
    4. Check the Device status area of the device Properties dialog box to see whether the error is resolved. If the error is resolved, you are finished. Otherwise, go to step 3.
  3. If the Troubleshooting Wizard did not help you resolve your problem or was not available, locate your error code in this article.
    Note If you cannot locate your error code in this article, contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus)
  4. Follow the recommended resolutions for that error code.
    • Check the Device status area of the device Properties dialog box to see whether the error is resolved. If the error is resolved, you are finished.
    • If the problem still occurs, unfortunately, this article did not resolve your problem. For your next steps, you may want to ask someone for help. Or, you may want to contact Microsoft Support to help you resolve this problem. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus
1helpful
Error code C:31:23
Dear,
C:31:23 is a S reel fault as per service manual..refer Page no.9 of the service manual version 1.1
Remove the cassette, battery,power and again perform all the functions and try.
Cheerup and Be Happy Always
Grand Canyon Tech
Grand Canyon Tech
