Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Monitor in powersave mode
I recently updated my video card, and when i tried to boot my computer, the screen was backlit for a second, and then it shutoff.
i have tried reseating the video card, and unplugging all the cords, waiting for a minute, then plugging them back in. everything is plugged in firmly, and i am struggling to find a solution.
please help.
Computer: Dell Dimension E510
    Genius:
  • 1,689 Answers
There is a possibility that the update you made was interrupted, please try to boot to safe mode then perform a system restore, once you ahve done the restore, please try to use another update for your graphics card if possible.
if you have other questions just let me know.
Posted on Aug 18, 2008
Beep codes on dell xps one 2010
If I understand your issue, it sounds like the display works fine until it loads Windows, and then it has the error? It sounds to me like the video card drivers are crashing. This may be the case if you have recently updated them, or installed a new video card. I would recommend getting the latest drivers from the manufacturer's website on a CD, SD card, or USB drive, and then boot your computer in safe mode. Once in safe mode, install the new drivers, and see if that will help. You could also try using your onboard (integrated) video card if your motherboard has one. This could help rule out if the monitor is at fault. Just make sure your BIOS has the integrated card as a secondary video device if it the (I'm assuming PCIex16) peripheral card isn't found.
Oct 06, 2012 | Dell XPS One All-in-One TV Desktop with...
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video card....you may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
TickMagnet
Aug 17, 2011 | Gateway 505GR PC Desktop
Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Aug 08, 2009 | E-Machines Celeron 2.3GHz (rb-t2385)
Comp. powers on, shuts down three times then goes into powersave
You may want to check the power supply fan whether it works properly or not. Also, you may need to check your BIOS setup if you had done anything with it.
Jun 23, 2009 | Dell Inspiron 530 Desktop Computer
Monitor keeps stating "monitor going to sleep" now awhile after booting up. The monitor works fine with other computers and the computer in questioning when in safe mode - yet if tried to boot normally,...
This is probably a video setting issue. In Safe Mode, Windows starts with low resolution and color settings, so the monitor can display them. But when it tries to start normally, Windows is using a video setting the monitor can't handle.
Start the computer and press the F8 key three or four times when the manufacturer's logo screen appears. This should get you to the Windows startup menu screen, and you can pick the option of starting in VGA mode. This will start Windows with video settings any monitor can handle.
Once you have Windows up and running, make sure the video card and monitor types are properly set up. It would also be a good idea to download and install the latest drivers for your video card. You can usually find them at the manufacturer's website.
Feb 01, 2009 | Compaq FS7600 17" Flat Glass Monitor
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
I was on my computer and I was on the internet. Then the computer screen turned into a creme colored screen with vertical lines going down the screen. I cannot exit out of the screen or restart the...
1. if your computer is locked up.. try to force a shutdown by pressing the power botton on your tower and holding the bottom pressed until the computer powers down. wait 15 seconds then try to restart again.
if your monitor is the one that seems to be acting funny... try with another monitor or logging into your computer remotely.. if that works, change your monitor, if it doesnt you need to troubleshoot your problem as follows:
2. you may have a video card driver problem: try the following:
last known good configuration
to restart your computer in safe mode by following this;
vista
xp
if you can go into boot into safe mode you do have a video card problem and most likely related with the driver... go to your video card manufacturer and lookf for an updated driver.
3. if you can't boot into safemode.. or not boot at at all you may have a hardware problem and based on the original description of your problem you video card is the one to blame. replace and retest
post your findings, more details of what happened after you restart or more details of your problem
Nov 01, 2008 | Computers & Internet
Powersave
If it's going into powersave mode, it usually means it's not getting a signal from the video card. Try plugging this monitor into another machine or laptop and you should be able to tell if that's the issue.
May 26, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
Second monitor - 'power save' mode.
Firstly, you can try to switch the second with the first monitor. Secondly, use only the second monitor as a main monitor and check that if there is still a problem or not. It might be because of BIOS. You can check and update BIOS with your computer manufacturer.
Feb 20, 2008 | LG L1918S-BN (Black) Monitor
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
59 people viewed this question
Alun Cox
