Question about Whirlpool GU2400XTP Built-in Dishwasher
Gritty white film all over dishwasher and dishes
The heating element has a thick layer of white over it
(this crust comes off when pounding on it) and the dishwasher itself has gritty film all over....dishes come out with white splotches all over... dishwasher is only 4 yrs old...
i have a whirlpool gold
  • tyy68 Apr 04, 2009
    Washer worked great fdor a few weeks and now every load has a white tacky dry film all over every load....I've cleaned the interior thoroughly and no change....anything plastic I put in the washer seems to get the most film on it and everything requires a handwashing afterwards...the machine has had less than 20 loads put through it.
  • robert tyrrell Sep 09, 2013
    I use a liquid soap/rinse agent, and have a hard white crusty build up. It's NOT hard water, as it does not happen to anything else. In the five yrs we've been here I've never had to clean my shower heads of scrub build up in toilet tanks. It's the soap. Every so often I have to tear down the entire top of the D/W pump/spray arm assys/and dispencer. Seems rediculous that w/ todays tech/advances in chem they can't come up w/ a safe phosfate alternative.But I guess if your Co has vested intrests in D/W mftrg/ parts/ the soap, creating prob's makes more $.
    Sniper:
  • 68 Answers
Another way to descale your dishwasher is to use vinegar. This is also very inexpensive. Put a cup of vinegar into the dishwasher and run it, allowing it to go through all cycles. I would turn the heated dry off.
Please rate this solution
Posted on Aug 19, 2008
Another not necessarily cheaper, but definitely more effective way to descale just about any cleaning system is to run CLR through it. used it on carpet cleaning systems as a replacement for industrial descaler. works just as good and is much more accessible
Posted on Jan 03, 2010
  • 487 Answers
This means that your water is extremely hard
You need to descale your machine with a good descaling solution. this you can get in a good hardware store
Posted on Aug 18, 2008
Tried something called LemiShine and it helped. Then tried Electrosol advanced dishwasher detergent (powder) and worked great! My glasses where all cloudy and had white residue, not with the Electrosol Advanced. I've heard Cascade complete also works well.
Posted on Mar 26, 2009
If you have this problem AND have an under ground sprinkler system or just had plumbing work done at your home in the last 2 months before this occured??? I can fix your problem in 10 seconds...Regards Rev. My glasses are crystal clear again...YEA!!!!!!! Food is not sticking and washing clean again YEA!!!!! revjeffrey@gmail.com
Posted on Jul 09, 2009
I also had this problem but was sure it must be something since it happened virtually overnight. One day it was fine, the next this awful white gritty film over everything. However I checked this site, saw the recommendation about Dishwasher Magic and figured that had to be cheaper than a new dishwasher!
I am delighted to say that it worked! Thank you for saving me the expense and hassle of buying something that was not needed!
Posted on Jun 28, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Posted on Jan 06, 2009
  • jpigott Dec 27, 2010
    I don't believe it is the hard water, our older Whirlpool that we had for 7 years never left this white film on the glasses and plastic spoons. We have a brand new Gold Whirlpool and it is just awful on the white file. It is quiter and has more room than the last one, so I hope we can resolve it. We used Jet Dry tonight and that was not any better.
    New Friend:
You have hard water. The film is the soap reacting with minerals in the water to form scum. Switch to a dishwasher detergent meant for hard water. Or, you can use a descaler like citric acid or vinegar in the rinse cycle.
Posted on May 12, 2013
  • judith May 12, 2013
    soapscum*
    Oh, lemon juice is high in cirtic acid, if you cant find straight up citric acid.
    New Friend:
Add a half a gallon of vinegar and some citric acid. That will clean it right up! Use vinegar in your rinse cycle.
Posted on Jan 07, 2013
SOURCE:
Our dishes and cutlery are coming out with a white gritty film on them. We have tried different brands of soap, rinsing agents and dishwasher cleaning solutions. Even with an extra rinse the film does not...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 04, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
Hi! I have noticed that my dishwasher is not cleaning the dishes like it used to. It is leaving a residue on all of my dishes and the glasses, usually, look horrible when they come out. It's driving me...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 07, 2011 | Frigidaire FDB1502RGC Built-in Dishwasher
After running the dishwasher, all the glasses and anything on the top shelf have gritty particles attached. The rest of the utensils and plates have a chalky white filmy residue on them. I have tried...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
heatman101
Dec 27, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Not getting dishes clean. When removing dishes they have a gritty residue on them
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 30, 2010 | KitchenAid 24 in. KUDP02FR Built-in...
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Thick white film forming on dishes
Check your heating element..
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Miele Dishwashers
My dishwasher is leaving a thick flaky residue on all my dishes and we use a rinse agent on nearly the max setting. The Heating element doesn't work.
heatman101
Jul 26, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
15,907 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
