Question about HP Compaq Presario V5000Z Notebook
Compaq Presario Laptop (M2000 series) hinge
One of the hinges is no longer holding up the screen, but other wise the display is ok. I have located the parts (ridiculous price) and the Compaq manual pdf. There is a procedure for removing the whole display unit, but nothing about replacing the hinges and internal brackets. There is no obvious way to get inside the display unit. Anyone ever cracked one of these? It's a borderline call as far as replacing the whole computer. Basically, if I can't do it myself, I might as well buy a new one. Thanks in advance.
hey all my l/s hinge broke and now the r/s is breaking....would love to know where to buy the part and how to repair it...looking forward to a resoultion!
  • wendycarlile Aug 19, 2008
    Thanks...I have started pricing everything and I believe that I am going to try to fix it myself. I CANNOT buy a new computer now. Wish me luck and I might be calling on you for more answers!!!
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
Posted on Aug 19, 2008
Tighten hinge on presario 700
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Mar 28, 2012 | Compaq Presario 700 470024-192 Notebook
I have a compaq presarion v4000 series laptop
yes it can be repaired it will cost between 40 and 150 depending on where you take it
Sep 19, 2009 | HP Compaq Presario v4000 Notebook
I have a broken hinge on a c300 . how do you replace that hinge. what all has to be disassembled?
Dear friend,
Try to find the similar hinge on your c300 at the nearest HP dealer, if you can't disassemble it just bring your laptop and ask for assistant, as far as I can remember, the hinge is sold as part at affordable price.
GoodLuck
Best Regards,
bionic23
Sep 09, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Compaq Presario C300 Screen Hinges
you will find small end rubber ( round flat) that is on the top 4 pcs and the bottom 2 pcs, remove this and keep this for a while, then remove the screws that goes along w it.
from there you can find out how to remove the LCD
hope this helps
Aug 01, 2008 | Compaq Presario M2000 Notebook
Compaq 1015v screen problems
Under the right hand hinge, the plastic hinge cover has cut into one or more wires
Unplug the battery, unplug the mains, carefully undo the 2 screws immediately under the laptop AT THE TOP in the middle undet usb / VGA socket roughly (on the base)
the plastic panel around the power on button (and volume buttons) will pop out carefully
take off the hinge covers carefully
examine the wires... solder them, insulate ... you will see the problem
the laptop "strecthed" out with the screen open strecthes the nicked wire and it disconnects... when you shut it, it reconnects
that ok mate?
Nov 06, 2007 | Compaq Presario 900 /1500 Series EVO...
Very easy to replace if you can get new ones. Remove the batter and remove all screws under the battery as well as all the screws to the right and left of the battery location (3 on the V5000). Now back on the other side gently pry up on the portion of the "keyboard area" directly above the keyboard. A small keyboard will make this handy
Now you'll see screws holding the monitor the the notebook. Remove those screws and the monitor will be freed. Be careful with the wireless antenna wires and xvga cable. Now remove all the little rubber pads from the monitor and you'll find all the screws underneath. Remove those and you'll see how the hinges are attached to the monitor. There are three screws directly to the screen and a few to the frame on each side. Remove those and the hinges will come off.
Replacement hinges are available from HP's website for about $50 + shipping but call them up and give them *hit and see if they'll help you out.
Nov 01, 2007 | Compaq Presario M2000 Notebook
Monitor removal
Ok then,  it;s a screwdriver job,
you need to remove the facia plate above the keyboard, and the keyboard itself,
this should get you a visual on the connections for the monitor,  the support screws for the monitor are in the hinges, (the covers for the hinges will need to be removed,
Oct 04, 2007 | Compaq Presario M2000 Notebook
HP Compaq Presario V5000Z Notebook Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
