E90 alarm code keeps coming up on zanussi washer
  • 54 Answers
E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
remove 2 screws at the back which secure the top,
push the top backwards,
unplug the connectors to the front panel,
vibrations due to unbalanced load may have loosened them,
push them firmly back in socket,
pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
power on,
run the machine empty for minimum cycle - rinse only.
Good luck!!!!
Posted on Aug 19, 2008
SOURCE:
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Can anyone help ive got a zanussi FJDR 1466 W. e91
    I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
    Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
    Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
    E90 code on a zanusi jet syatem turbo dry 1600
    A E90 fault code means the main pcb board is faulty and i'm afraid to say, they are a expensive item and not always easy to replace, some come pre programmed and just swap across and others have to be programmed using the code on the white sticker on the board housing. either way it normally better to get a engineer to replace it because you don't get the programming instructions with the new pcb. I hope this helps
    Jul 14, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi jet system 1000
    Jul 09, 2008 | Zanussi FJS1225W Front Load Washer
    ZANUSSI ZWD1471S
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Washer whilst washing keeps flashing up with E90
    Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
    Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    Zanussi
    E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
    Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
    E90 Error Code
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    810 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
