Question about Garmin Quest GPS Receiver
Will not turn on
Had been setting for three years i replaced battery and it came on and after about one hour it tried but would not come on, screen would come on and go off
  • Anonymous Feb 07, 2009
    I have the samne problem, my son and I were give one Garmin Quest each as presents, both no do not switch on. there's is nothing wrong with the charger
    anyone help
    Problem Solver:
Try to reset the unit by pressing Power + In buttons simultaneously
Posted on Oct 16, 2009
Your batery is kaput or needs charged. use the AC charger.
Posted on Dec 12, 2008
Can i replace the battery in my Royal EX2 Exacta Scales Postal scale?
90 day warranty on this scale to begin with so when battery dies after 10 years, you have no warranty to preserve. Royal EX2 Exacta Scale - royalsupplies.com - manual downloadable.
You will need a Phillips #1 and I think a #0 for best fit. 2032 lithium coin battery (fresh, so it will last another 10 years). 1) Peel off large label from bottom (Xacto knife to get under a corner). 2) Remove 3 screws attaching pan to mechanism. Use magnitized P0 screwdriver here. 3) Remove 4 rubber feet, and four P1 screws under them. 4) Opposite side of display from the button is the black battery case. Use P0 screwdriver to remove three screws. Replace battery. 5) Put back together...
Don't mess with the mechanism inside (at least not if you want a calibrated scale) any more than you have to while changing the battery.
Jul 04, 2012 | Health & Beauty
Hi, i have a portable dvd player & the battery is 2 hours. now it only lasts 30 minutes. is there something i csn do to boost it or do i need a new battery. thank you, medina
Your best bet is simply to replace it with a more reliable battery. However, starting the dvd player without a disc so that the settings appear should allow you to change the options on the DVD player. This should allow for the brightness and picture settings to be adjusted to preserve battery to the best of the DVD players ability.
Step One: Remove Disc
Step Two: Turn On DVD Player
Step Three: Enter Settings
Step Four: Adjust the picture and screen settings to maximize the battery life (make the screen less bright for an example)
There may be a setting specifically meant to maximize battery life. Hope This Helps.
May 13, 2011 | TruTech PVS12701 Portable DVD Player
Sony dcr hc32 clock set comes up but nothing works on the touch screen.
I've had this problem with my HC32 touch screen for a year and a half.
To get the touch screen to work:
- I put it in the charger dock and turn it on AND LEAVE IT ON so the screen is displaying something (anything).
- within 12 to 24 to 36 hours it starts to work on it's own. At first it will only let you make a single menu choice and lock up again but a few hours later it will be perfectly normal for at least a few days (maybe forever if you use it regularly).
I've done this three or four times now and it has worked each time. It seems that after it sits a few months and the battery discharges the problem occurs.
Feb 10, 2011 | Sony DCR-HC32E DV Digital Camcorder
Can not start,hear clicking sound in the fusebox ,the bike was in a shed for more then 3 years.
Make sure you have the proper water acid level in each cell of the battery. Then, connect your battery to a trickle charger, which is a charger that puts out 1 - 3 AMPS continuous. Leave it connected for 48 hours. Disconnect the charger and allow the battery to stabilize for about one hour. Then check your battery voltage. If it is 12VDC try and start the motor. If it is below 10.8VDC, replace the battery. Most motorcycle batteries don't have a very long shelf life, and your battery is probably no good for sitting for more than three years.
Mar 31, 2010 | 1997 kawasaki ZX-6R Ninja
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Garmin Quest GPS Receiver Logo
460 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
