Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Unidentified symbol on panel
We have a symbol which looks a bit like a shopping trolley with a tick on the side that has come up on the panel of our American side by side Fridge Freezer, and would like to know what it indicated.
  • 61 Answers
Runaway trolley problem?
In The Wrath of Khan (1982), Spock says, "Logic clearly dictates that the needs of the many outweigh the needs of the few."
https://www.theobjectivestandard.com/2013/09/spocks-illogic-the-needs-of-the-many-outweigh-the-needs-of-the-few/
Jan 04, 2017 | Homework
How do I wind bobbin on unidentified machine?
take the bobbin in an unidentified machine and turn it round and round. Go to a sewing repair shop and ask them.
Oct 03, 2015 | Sewing Machines
Door will not open. Trolley moves towards door then forward an inch or so then stops.
Adjust your open and close positions on your door opener. Only adjust one at a time. Once you make an adjustment try to open and close. If it gets worse, go the other direction. If it does not change anything, then go to the other adjustment and repeat the process.
Nov 04, 2017 | Building Materials
I have an old Monark Mark11 Stationary excercise Bike and when using it the tension releases while using it. Don't know how to take the side panel off to look inside. Please help. thanks
They will probably found in a "torx" set of screw driver bits
Got to a good tool supply shop and ask for torx bits and see if any of the bits look like the screw heads on the bike
Jan 24, 2015 | Cars & Trucks
Put jack stands uder a 2001 Lincoln LS
place the trolley jack under the front cross member . (The big bit that connects the side frames under the sump). Lift as high as possible and place the jack stands under the chassis ( moulded rails ) where the sub-frame meets . Then place the trolley jack under the rear diff and lift as high as possible Place the jack stands under the chassis at the front of the springs or track rods By using these positions you will have the cabin securely jacked up with all the wheels free to remove or to work on. Before going under try rocking the vehicle hard to ensure that it will not move off the stands.
Mar 15, 2014 | Cars & Trucks
Jacking points on a 2013 astra gtc sri
these will be behind the front wheel and in fron t of the rear wheels ,look for a sort of cut out bit that the jack head goes into failing which use a trolley jack
Sep 06, 2013 | Cars & Trucks
Sienna middle seat track removal
Since none of the other answers appears relevant (they were written years ago and appear to relate to different problems), I spent about an hour digging into this and regret to report that the simple answer appears to be that there is no easy way to remove the tracks and 2" trolleys on which the seats are mounted.
The best solution appears to be taking a large piece of styrofoam-like material the size of the floor you want flat (since the compartment into which the 3rd row of seats retracts in the 2013 is an inch or so high itself, maybe you don't need to cover that part of the floor, but you probably would need to cover everything else. Then you cut out part of the styrafoam where it's going to fit over the offending trolley mechanisms, lay it down upside down on top of them, and, however mickey mouse it looks, at least it's flat.
One individual who wrote a post elsewhere on this appeared also to have followed up the styrofoam with a large piece of plywood, which gave him an even flatter, but once again elevated, surface.
I'm someone who thinks anything's possible, and I'm sure taking out these rails and trolleys IS. It begins to appear, though, that it's something that would involve partial or total disassembly of the floor of the vehicle, likely starting underneath the car (since there are no bolts that are readily visible from above anywhere in the track slots). And THAT begins to sound like a project for which you'd want to make the first step the acquisition of a shop manual.
Sorry. I have the same problem. Wish I could offer you something a lot simpler. It is a little bit of a surprise that the manufacturer's engineers wouldn't have anticipated the need of some owners for a totally flat floor.
Apr 18, 2013 | Cars & Trucks
Maytag Side by Side Model GS24C6C3E
Refers weight several hundred pounds. Yes, you can move on a trolley, just do not lay flat without noting the refrigeration piping as it exits the compressor. You can only lay the refrigerator on it's side where the piping is pointing up.
Dec 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Unidentified warning symbol came on
What does the symbol look like? If you can send me a pic at Kennykbe@hotmail.com I can tel you.
Aug 02, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
129 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
