The fuse in question also powers the instrument panel cluster ,also goes to SP200 -splice pack 200 where it powers BCM , CCM,multifunction switch - turn sig. headlamp dimmer switch and the WSW .Also if you have utility vehicle without memory seats it powers the front seats lumbar switch . Do you know how to check circuit's for a short ? Locate SP200 Splice Pack SP200
(CKT 41, CKT 241, CKT 341, CKT 817) Strapped to the body harness, under carpet in the RH dash area about 30cm (12 in) from the right kick panel .Do you know what a splice pack look's like ?
Disconnect circuit's one at a time till the fuse doesn't blow , then you found the problem circuit or componet . Disconnecting the BCM will cause the vehicle not to start an run . Anti-theft system . You mite try having the BCM checked for DTC'S - diagnostic trouble codes
