Question about Linksys (WRT54GC) Router
ROUTER SIMPLY WONT WORK WIRELESSLY AT ALL
I set up WRT54GC wireless router, by connecting via cable, and running the CD that came with it. I then went onto the net 192.168.1.1 and set up the security settings. I then removed the connecting cable and the thing simply won;t work. I cannot even locate it. Have searched for help on the net on this for hours at this point but have had no luck. Can anyone tell me in simple language what I need to do!
  • 49 Answers
Who is your internet Service provider? if it is cable then go to the same 192.168.1.1 page and do a MAC address clone. Enable it first and click on Clone. Make sure tosave your settings below.
Make sure you have an ip address on the Status tab to the far right before removing the cable ethernet wire you used.
If it is DSL change your local ip address to 10.10.10.100
and perform a powercycle.
POWERCYLE
means switching everything (modem, router, and PC )off for 30 seconds.
thanks...
Posted on Aug 25, 2008
    Genius:
  • 1,689 Answers
Firmware reflash:
if the router's SSID is not broadcasted even though it is on "SSID Broadcast enabled" under the wireless settings, you may need to reflash the router's firmware if a HARD RESET did not work.
Hard reset:
this is pressing the reset button on the router for 25 seconds, unplug and replug the power cord while reset is still pushed, then let go of the reset button once the power is plugged back in.
Firmware upgrade:
Click here to get the steps needed to be done.
if this still did not work, you may want to contact Linksys tech support at 1-800-546-5797 for further troubleshooting or an RMA depending on the status of the device.
Posted on Aug 20, 2008
Loss the setup CD-ROM
A setup CD isn't needed to setup the linksys wireless router.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2013 | Linksys (WRT54GC) Router
Well i had my router all setup n working fine for around 4 months, then our cable modem went out for like 4 days after which it has been giving me fits. I can get my pc connected but it seems like the...
1. you will have to contact your ISP
2. you will have to clear the router and use the setup CD and reconfigure the router
the Internet Service Provider probably has changed the IP address.
3.check with the router manufacture via their web site and see if there are and updates for your router.
4. you will need to check your firewall setting in the Windows Security settings.
5. you will need to setup your wireless devices again via the Wireless setup wizard provided in the router wireless settings. These instruction are on the CD that came with the router an or the manufacturers website will provide step by step instructions.
Feb 07, 2011 | Trendware TEW-432BRP Wireless Router...
The linksys network has disappeared from the list of choices on my computer. To try fixing the problem, I've reset the router via reset button but it didn't help. However, that did restore the router's...
You need enable wireless in router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on wireless and enable configure it as AP mode access point mode.
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Aslo make sure WAN settings are perfect with your internet service provider.
Enable DHCP if you want ip from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 27, 2010 | Linksys (WRT54GC) Router
Wrt54gc wirless router lights keep blinking. cannot connect via wireless router, modem is ok.
which lights keep blinking ? I would do a factory reset - button on the back - hold for at least 10secs it should then reset back to the factory condition connect the modem to the wan port
quite often the default settings may work with the modem.
post back a comment and detail the status of each light on the router also the make and model of the modem and the status of each light on the modem
Mar 21, 2010 | Linksys (WRT54GC) Router
My WRT54GC won't let me into the control panel. I've looked up the solutions for hours, and i can't get it to work. I'm using a MBP and a HP Pavillion dv6000, and it's the same with both of them. If i...
If you connect the router (WRT54GC) to your broadband modem does it then allow wireless action? Your router has an Internet address. It is 192.168.1.1, in all probability. Check your manual to be sure. Access to the control panel is through this address. You must log in to the router then set up the Wireless, the SSID (the name you give your network) and any security you set up. I prefer the WEP-PSK[TKIP] as it's easiest. Other things with the router, settings and such, pretty much are set automatically, so once security is set you should be good to go. Good luck !!!
Nov 11, 2009 | Linksys WRT54GC Compact Wireless-G...
My Linksys wrt54gc quit working. I get amber
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Thanks.
Nov 06, 2009 | Linksys WRT54GC Compact Wireless-G...
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
My electricity went off and now my connection is open but my comp
You need to reconfigure the router. The power outage probably resetted the router to it's default settings. In the default state the router doesn't have any wireless security; hence the "unsecured network" warning from your PC.
Connect your PC or a laptop with a cable to the router, surf to (http://192.168.1.1 or https://192.168.1.1 - ignoring any security warning); which is the configuration interface of the router and follow instructions in the manual.
When you have a Linksys configuration CD, you can simply run the "Easy configuration" setup after connecting your PC with a cable to the router.
Plainly put you just have to configure the router just like when you first used it.
Feb 09, 2009 | Linksys Wireless-G WRT54G Router
Open Questions:
Linksys (WRT54GC) Router Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
